Trans fluid level.
Old Apr 29, 2007 | 09:08 AM
joeman892's Avatar
Trans fluid level.
I installed a transcooler on my car the other day and i figured that with the installation of the unit, plus about 10 feet of 3/8ths hose that i would be about a quart low. so with out hesitation i added the quart. Then i checked the dip stick and to my surprise i was about 1.5 inches above the 2 cut out circles on the bottom of the dipstick. I also noticed at the very top of the dipstick there is another cut out circle. I read the owners manual and it said that the level should be between the 2 circles but it doesnt specify which one. So judging by their picture in the manual i guessed it was the bottom 2. I drained out about a half quart and the level is still about .5 inches above the 2 circles so now either i was over full to begin with or im supposed to be higher, becuase a half quart will not fill all that hose and new cooler space. If someone could check their dipstick or just post some help i would appreciate it, thanks.
Old Apr 29, 2007 | 10:25 AM
01tl4tl's Avatar
With the trans warm from driving 15 minutes, the turn engine OFF and remove and clean then reinsert remove and read the trans dipstick, should be between upper 2 marks, the lowest one would be out of fluid!
SidhuSaaB
May 30, 2020 12:40 AM
LeVeL
Oct 18, 2015 04:19 PM
Houston
Oct 8, 2015 01:27 AM
steve
Sep 30, 2015 09:23 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
