Tell me everything i need to know about the UR Crank Pulley???
99TL-p 114K
What are the pros and cons?
Could i expect any future problems from the UR Crank Pulley?
Will i need new belts' or a new belt by having the UR Crank Pulley put in?
If so what new belts' or belt will i need exactly?
Any heads up on the UR Crank Pulley would be appreciated. Thankyou.
I get mine installed next week ill post an update on this thread otherwise do a search it helped me a lot before i bought mine......And you do need new belts
pro= better throttle response and some more power. no cons
no i wouldnt expect any future problems, i havent had any with mine
you need 2 new belts for the installation
search to find the part numbers.
TL-S driver
actually there is one con, not a big one but one non the less. The AC does no kick in as quickly for some unknown reason. Other then that, the gains are significant. You should also know that it will take a few days before you really feel it, give the cars computer a day or so to "learn" how you drive.
http://www.ntpog.org/reviews/underdrive/pulley.shtml
read here and go down to "update read" talks about the problem with the main bearings being pre-maturley worn, since the aftermarket pulley doesent prevent any harmonic problems. in other words its not balanced and it shows on the main bearings. im not sayin you will have immediate problems but you will def lower the life on your motor..
Received 1,080 Likes
I think you need to read up a bit more. On a Prelude, I could see premature wear. The Prelude has a harmonic balancer on the crankshaft. It's designed to deal with crank pulley vibrations.
The TL thankfully does not utilize a harmonic balancer.
Here's some more posts on what a HB is and proof that our cars do not have them,
Former Sponsor
I need 2 more gears
better throttle response, more low end torque, smoother idle and overall engine operation, lighter and responsive steering(and I don't have the power steering pulley, weird?). cons= you will be hitting v-tec more often because you love the new found power and your gas mileage will go down some, if that's a con, not to me! UR pulley is awesome, very nice gains!
Only con I can find is the install. It sounds like a PITA to get that bolt off to remove the OEM crank pulley. Other than that, I'm really thinking about this one. And I'm a non-modder.
I'm a non-modder, non DIY'er, no skills whatsoever type of guy, but even I've got the bug on this one. Made some calls yesterday to see who will install it in my area. Acura won't and one other place I called around here won't. I'll keep trying though because this sounds really good...
Drivin' it till it dies!!
Are there any special tools/instructions needed to remove/install the crank pulley?
I'm about to order the Ultra SS set (three pulleys). It looks like the alternator and ps pulleys are self explanatory, but on the instructions listed on UR's website, it says to consult the repair manual for removing the crank pulley. Any input from people who have done it would be appreciated.
I need 2 more gears
I have learned using a pulley holder and long break bar is the best way because a lot of impact wrenchs aren't strong enough to get the crank pulley bolt loose. If you are not a hrd core DYI'r I would have a mechanic do it. I do as much as I can myself, but didn't want to mess with the crank pulley because it is so important to the life and proper operation of your engine.
I'm pretty sure I can handle it, I was just wondering what exactly the service manual says about taking the crank pulley off.
Will I be doing any harm by using extensive force on the pulley nut (loosening/tightening to specified torque)?
Is that where I would need the pulley holder (used to stop the pulley from spinning, I assume)?
its nothing special, once you get teh belts off you remove the crank bolt. (which can be a the hardest part, there are acouple ways of removing it) you may need a pulley puller (can rent at most auto parts stores) and remove the pully. Then just reinstall the new goods
Hey pistacio,does your car scrap all the time??I had to recently raise my car to two finger gap,got tired of scraping plus I was on my second set of megans headers already..........lol
Thanks fsttyms1!! I didn't think there was too much involved, thanks for confirming.
Just ordered them and I can't wait!!
Thanks Phesto! The pics I have are when I had the air ride installed (what a PITA!! that was) and was parked. I couldn't drive that low,lol. It did look sweet laid out and I'm going to miss it, but since I removed the air ride I'm dropped on coilovers now, but not much higher than the pics! I have about 1 to 1 1/2 fingers in front, and zero to 1/2? in back. I'll have to get some pics up soon. I don't really scrape, it just takes some careful driving.
Whats Your next MOD pistacio? And what type of coilovers did you get?
I am wondering if my grill would look as nice as yours,if it were painted AM.Very Unique,Very NIce
funny i must have one of the odd tl-s motors out there with one on..
clearly has the rubber mating the two pieces togather which would eliminate the crankshaft twist (not vibration like everyone thinks, vibration is just the outcome of too much crankshaft twist.). oh yea and the 4 "balancing" holes drilled into the inertia section of the balancer or "pulley" if you want to call it that. our engines (as well as the h22a4) might be internally balanced but theres no way "internally" to eliminate the crankshaft twist which only occurrs on the pulley end of the crankshaft. i have done my homework, and have been doin it for the past 5 years fixing cars. both heavy and light maintenance.. and just so have it i am also an aircraft mechanic in the airforce and have been doing that for the past 10 years. i dont claim to know everything as i do learn new stuff almost every time i work on a car, but the basic understanding of how things work i pretty much have covered. just to keep on subject the crankshaft pulley will not do any immediate dammage but it will shorten the life of your crank bearings.. could be alot could be alittle.. every crank is different. good luck pimps..
I've been snooping around thinking about the pulley for a while. I've been holding back because I think I remember hearing about how the comptech supercharger can't coexist with the UR Pulley. And since i plan on S'C'ing soon, I wouldnt get the pulley since it'd be out in a few months anyway. Does anyone know if this is true? Or should i begin extensively searching the CL forum
99 SSM Tl
Unorthodox website ... :
Standard Belt Layout (Underdrive)
Our pulley sets provide most of the power gains through weight loss (80-85%). The remaining part of the gains from these pulleys comes from underdriving of all the accessories (15-20%).
99TL-p 114K
My Last Questions and Concerns about the UR Crank Pulley before i order it
Ok, Here are my last few questions and concerns i have about the UR Crank Pulley for the 99TL. Please answer my questions if you have the answers to them.
1. Can someone please explain to me why u have to change BOTH belts when your only changing one pulley that runs on one belt, that is not attached to the other belt??? Or am i all wrong?
2. Are there any fitment problems with using the Gates brand belt sizes that UR suggests for use with the Crank Pulley? For example..... Do the Gates Brand Belt sizes fit nice and tight around the pulley, like is the tension nice and tight and not loose??
3. Why do i have to change the belts when having the Crank Pulley Installed, i know i need to, i just wana know why you have to??? For example..... is it because the UR crank pulley is smaller in size or bigger in size???
4. What affect is the UR Crank pulley going to have on the Air Conditioning and anything else thats electrical on my 99TL??? Is it going to mess up the Bose Headunit or not supply as much power to the bose amp and what not??? Is my dash lighting going to become less bright and more dim???
I need these answered ASAP, wana order the pulley tommorow but not until these questions are answered. Thanks alot for anyone that can help.
291hp & 245 tq @ 3.5psi
Ok, I take a shoot and answer your question up to my knowledge.
1. You need to change both belt because the crank pulley connect to both belts. I might be wrong on this since I have the whole pulley sets.
2. I have no issue with fitment on mine car so far for almost 3 weeks.
3. If you order underdrive pulleys, then yes, you need to change the belt because the crank pulley is smaller 20% than stock one. If you order stock size pulley, then my guess that you dont need to change the belt.
4. I have not notice any different in AC power, radio, headlights, or any electrical issue since installed 3 weeks ago.
Hope it help.
Hope it help.
99TL-p 114K
Hope it help.
Hope it help.
Originally Posted by Rpappi
any one else have any opinions on the electrical system with the underdrive pulleys. IE loss of power
acuratl26
04-23-2020 07:30 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
