Stock OEM or Aftermarket Water Pump
Old 09-16-2005, 04:49 PM
acutee's Avatar
Hello all,
Do you have any suggestion if I should use Stock Water Pump or Aftermarket Water Pump? Which one is more reliable? I want to replace the water pump when I do my timing belt. thanks much.
Old 09-16-2005, 05:00 PM
PenancE's Avatar
id say stock, btw i never seen a aftermarket pump....
Old 09-16-2005, 05:20 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
most waterpumps you buy in parts sotres are rebuilt oem units, or built to oem specs. id say whatevery you find or want to spend on it. both would be fine
Old 09-17-2005, 06:06 PM
2010 TL SH-AWD
S power's Avatar
I just bought a waterpump from Uglyphyscho on this board and it was from Napa. Looks identicle beside the Honda sign on the orginal. The Napa one was made in Japan which was printed on it. It is brand new and not rebuild.
I just got done with the timing belt change and remember to get a good clamp and a good steel pin that wont bend for the auto tensioner, it was a bitch I tell ya. Make sure you triple check all the teeth marks by rotating the pulley because the new one is not as stretch as the old one and mine was like a teeth off . Luckly I recheck it.
Old 09-17-2005, 10:14 PM
acutee's Avatar
Thank you guys for the info. One more question, what tool would you use to compress the hydrolic auto tensioner? Thanks
Old 09-17-2005, 10:47 PM
2010 TL SH-AWD
S power's Avatar
a 6" C- clamp should be ok. and a small drill bit(tempered) use for the pin.
Old 09-18-2005, 09:39 AM
acutee's Avatar
Great. Thanks much. A drill bit is a great idea for the pin. Thanks again everyone.
merc009
09-14-2015 06:43 PM
christopher1
3G MDX (2014-2020)
09-10-2015 06:43 PM
asahrts
09-04-2015 05:55 PM
trinikidcl
09-04-2015 12:56 AM
MyKids&Cars
09-01-2015 12:53 PM
Quick Reply: Stock OEM or Aftermarket Water Pump
