stick conversion?
Old Mar 19, 2012 | 01:53 AM
eddiex77's Avatar
6th Gear
stick conversion?
is it possible to convert 2nd gen tl to stick?
Old Mar 19, 2012 | 02:01 AM
NIGHTEHAWK's Avatar
Big plans not enough $$$
Anything is possible with money.
Old Mar 19, 2012 | 03:31 AM
Karanx7's Avatar
Unregistered Member
Yes it's possible, and it has been done several times. Check out the 6 speed threads compiled in the DIY list. You have a few options:
If you have a TL-P
-Complete CL-S convert (Engine, Tranny, ECU, Wire Harnesses, Cluster)
--ABS doesn't work, Air Bags don't work, Moonroof doesn't work
-6spd Convert (Tranny, Richie's Module)
--Everything works, but you won't have a Type S engine
-Type-S 6spd Convert (Engine, Tranny, ECU, Cluster, Richie's Module)
--You basically now have a Type-S with everything working
If you have a TL-S
--You will still have to change certain components of the engine
--Everything works. Easiest/Best option IMO
In all of these situations, VSA/TCS will not work. All Acura trannies have LSD, while Honda ones do not.
Old Mar 19, 2012 | 09:36 AM
fsttyms1's Avatar
Please see the DIY section, there are a few in there and do a search with the search button, there are even more.
Old Mar 19, 2012 | 02:28 PM
eddiex77's Avatar
6th Gear
thanks im going to look into that
knight rider
Mar 4, 2016 08:59 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
spoiler900
Sep 23, 2015 04:41 PM
