rotor swap
Old May 22, 2014 | 05:09 PM
Hightowerua1's Avatar
rotor swap
I have a friend that bought some cross drilled rotors for his 04 tl but found out that they didn't fit because he has the Brembo calipers. Would I be able to use those rotors on my 02 type s?
Old May 22, 2014 | 05:21 PM
Skirmich's Avatar
Yes! Front brake discs are identical to the 04TL-p with no Brembo Brakes, It didn't fit his because Brembo Brakes uses a Larger Diameter Rotor.
Old May 22, 2014 | 07:07 PM
Sweet thanks for the info!
Old Jun 6, 2014 | 11:37 AM
Excelerate's Avatar
Former Sponsor
The 3G TL-S/TL Brembo rotors will not fit the 3G TL Base non Brembo or the 2G TL unless you buy a number of other parts.
Old Aug 4, 2014 | 11:22 PM
TEXAS TL-S's Avatar
8th Gear
do not cheap out on rotors they will warp. if you want to upgrade from stock you may want to get a quality rotor such as a bosch rotor and throw some upgraded ceramic pads for better stopping power. you get what you pay for however. not everyone can afford brembro. This is an effective alternative to stock.
Old Aug 5, 2014 | 09:06 AM
fsttyms1's Avatar
Brembo Blanks are not expensive
Old Aug 5, 2014 | 01:12 PM
03 tls nc's Avatar
Picked up a new set EBC slotted rotors $120 shipped for the pair...after a 15 min google search.
Old Aug 6, 2014 | 09:56 AM
bonknhead's Avatar
x2 EBC GD Sports, dimpled (not drilled through) and slotted, paired with Redstuff pads are great! On my second set of RS pads after 35k on the first set. No need to turn my EBC rotors either.
TypeS860
Jan 10, 2026 11:11 AM
Jul 16, 2017 07:33 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
hpfiend
Sep 27, 2015 06:59 AM
