Removing crank w starter??
Old Jun 28, 2012 | 02:44 PM
MilwaukeeDave's Avatar
Has anyone used this method?? Breaker bar and socket on crank bolt facing front of car and just "goose" the key a bit to get starter to turn and break bolt loose. I don't have a very strong impact wrench at home that can do it. If this isn't ok, any other suggestions?
Old Jun 28, 2012 | 02:46 PM
fsttyms1's Avatar
That is the way most do it. Or you could drive up here and i can get it off for you.
Old Jun 28, 2012 | 06:23 PM
I may have to take you up on that offer. But first I gotta ask the warden aka my wife lol for a day pass. You're about 2 hours north correct? Like headed to GB?
Old Jun 28, 2012 | 07:38 PM
fsttyms1's Avatar
Yep, take 41 nort. Depending on where in MILW you are located its only about a hr and 30. im 30 min south of GB. I can make it to waukesha in about a hr and 15ish
Old Jul 3, 2012 | 11:56 PM
Borrowed a pretty powerful impact gun from work. It should work.
Old Jul 4, 2012 | 07:33 AM
fsttyms1's Avatar
Its not the impact gun that is the problem. Most all would remove it. Its the air source. Most compressors found in peopes garages arent strong enough. Sure the go to 125+ psi but they just dont have the sustained volume (cfm) to do it.
My offer still stands if it doesnt work
Old Jul 4, 2012 | 08:42 AM
Ok cool. Headed to buy an impact socket now and give this a try in a while. I'll let u know how it all goes. Hopefully I won't melt into a puddle under my car.
Old Jul 4, 2012 | 10:43 AM
Apparently no one sells individual 3/4im drive impact sockets in a store so using breaker bar and starter. Whoops!
Old Jul 7, 2012 | 02:23 AM
Ruyguy331's Avatar
hey did the starter/breaker bar trick work for you? installing a UR pulley soon
Old Jul 7, 2012 | 10:19 AM
MiddleAgeCrisis's Avatar
"Inherited" 1999 TL
I thought the breaker bar trick would not work because our engines rotate CCW. Is that not the case?
Old Jul 7, 2012 | 10:39 AM
Must turn CW. After a quick search I see many people both TL and CL have used this method. I haven't gotten to mine yet because my central air took a crap and I had to take apart and fix that instead. Maybe today after I'm off work I'll give it a whirl. It does work though, I've seen many posts about using this method. Now I need to figure out how to get the alternator and P/S pulleys off!
Old Jul 8, 2012 | 09:58 AM
Hey will the engine spin backwards?? If so how do I torque the bolts back down again??
Old Jul 8, 2012 | 10:17 AM
Ok I worded that very badly and I waited too long to edit but basically how do I torque the pulleys??
Old Jul 8, 2012 | 07:47 PM
It works very well!! I just used a medium depth socket, 3" extension, and 1/2" drive breaker bar. If your bar isn't long enough, mine was 2 feet, just stick a wood block underneath it. Probably should use the wood either way I'd imagine just to avoid scraping your tool up and/or gouging the concrete. It took 3 bumps of the key to get it broke loose. The first 2 were very quick bumps as I was bein tentative so I didn't fail and destroy shit. After the first 2 I repositioned the bar to closer to 5 o'clock and use a shorter wedge of blocks and gave the key a jostle. Broke free no issue then. Took my puller and had to make it a 2 arm puller because there's not really enough room to fit all 3 on there. Used a socket in the pulley hole for a spacer and it was off in 5 seconds. I'll post some pics of finished product as soon as photobucket will let me. Alternator pulley will get on eventually but didn't wanna pull alternator off today.
Old Jul 8, 2012 | 08:21 PM
Old Jul 8, 2012 | 08:28 PM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
Looks good. was it difficult? I had my mechanic do mine for 30$
Old Jul 8, 2012 | 09:43 PM
Hardest part was putting the belt back on and getting a bolt back in the P/S pump. 30 was a good price considering u gotta take the wheel off, splash guard down (4 push pins worked), belt off, pulley off, then reinstall.
Old Jul 8, 2012 | 11:18 PM
Yeah he went to high school with my dad so he gives me a good deal
Old Jul 9, 2012 | 10:03 AM
fsttyms1's Avatar
With a torque wrench
Old Jul 9, 2012 | 10:12 AM
I figured it out. Just was curious if there was anything to know for tightening it before I did it since the crank spins that way as well. Didn't wanna stick nothing in the holes of the new pulley and cause damage.
Mike Pilipenko
Mar 26, 2024 09:21 PM
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
agupta3224
Sep 22, 2015 08:08 PM
