Rear custom strut bar
so right click on pictures...
properties..
or .png.. or watever it is..
if you're using firefox.. it should be
then.. once you have that right picture link
[ img ] link [ / img ] <--- minus the space
properties..
i would like to see this. but its not gonna do much, seeing how our seats are foldable and we have those triangles behind the seats for stability. a lower tie bar would be great.
http://photos-g.ak.fbcdn.net/hphotos..._6279752_s.jpg
http://photos-b.ak.fbcdn.net/hphotos..._6407327_s.jpg
lemme kno if this works, i uploaded them to my facebook
looks more like a brace bar rather than a strut bar..
strut bar would bolt to where your strut towers are..
thats like...
a "c-pillar" bar..
thats like...
a "c-pillar" bar..
MUCH BETTER PICTURES
, but did you even reenforce the strut towers cause it looks like you just welded the steel bar straight to it with just sitting it straight on to the lip created by the inner sheet metal
(reenforce in like a 6x6x0.25 plate so it does not punch through or eventually tear the sheet metal from the small weld area)
https://acurazine.com/forums/members/flacoj-256468-albums-custom-rear-strut-tower-brace-4342/ all pics for ur viewing pleasure of the junk in my trunk, litterally
the welder is 6'2 ,climbed in the trunk backwards and almost caught everything on fire he removed to welders mask frantically to blow out the flame, welding to such a thin metal in that position is ruff. We tried to yank it off and it didn't, so its good, meaning it serves its purpose the bar costs $8 and change plus some creativity, and a welder willing to climb in your trunk and mess the least amout of stuff up, U to can enjoy more repsonsive handling, and better ride quality
about the fire, that its why you have compressed air next to you or something (btw: was it the paint that caught on fire?)
the weld job was done, kudos to every big person that can manage to contort into a trunk and operate their hands
now if yall are offering to reweld my strut brace, to make it look pretty with all of yalls great abilities be my guest, or if u really wanna show off, do the mod yourselfs and take pics of you doin it, nothing funnier than a big person in something small
otherwise your just tooting your own horn for no reason, the same thing goes to the over sized gentleman who wired his own amp, I am glad big people are able to do work with there hands aswell! if they had a gold star icon id place it right here
I think its doing some work.. Probably not the best spot where you reinforced it... Maybe you should try making some plates, and actually bolting it down to the strut towers??? I've done a front and rear before, and its pretty damn simple... if you can grind, drill, and weld, then you'll have a badass bar for cheap, and unique..
its less than five inches from the where the strut bolts down, and it sits just above the layer of cheap thin metal that blankets the strut tower, doing anything out side of the trunk would take away the luxury appeal if I was to eliminate the felt carpeting on the back dash, then id pay alot to have a bar fabricated that i could bolt in with the strut it self, its a tight fit to even get your hand in there much less a fabricated bar with bolt hole flanges to be bolted down, The bar is as effcient as one piece of metal could be, it is very unintrusive, u have to bend down to see it. All this extra fabrication would cost more than 8 bucks.
: that area does not see a whole lot of flexing because the upper controls are attached to the subframe so it is only the strut tops there, but it could lessen the chassis twisting a little bit, but i don't think anything that noticeable, but each to their own, still redo the welds though and reinforce it though
but the funny thing is that
there is very little that would actually move in that area, the strut towers are already tied into the rear deck to keep stiffness. Also what is the size and gauge of that steel bar? It doesnt look like its that big
to say the welds look shitty and need to be redone, also next time try cleaning the paint off (grinding) the paint off first
