question on a cam shaft swap ???
I was told that the only difference in the TL and the TLS motor in 99 (3.2 ,s.o.h.c. v-tec) was a different cam shaft. I scanned through a bunch of threads and didn't see anything on it. so my question is if that is the case where do i get one new and what would a part and or model # be for it ......... Thanks
2000 acura tl FPR
welcome to the forum
http://estore.honda.com or
http://acuraoemparts.com for discounts on the same parts
the cams are more aggressive in the type s, the type s also has higher compression and better TB and IM. you are probably better off just doing the engine swap. too much work IMO
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Thanks for the info. i figured there was more to it than just a cam shaft. I did find a S motor for 800.00 w/80k is that a decent deal ,and will it bolt up to the 4-spd tranny thats in the car already? If so how would that effect the performance?
B A N N E D
but working fully, and relizeing the full potential of the type-s motor, NO since you will have to use that 4-speed PCM, which is not tune for that type-s motor, but you can get an AEM FIC to get back some of the potential there though, but you are still going to limited to like a lower redline and such though (and getting the IMRC is going to take a little bit more work to get it fully functional though, since if you do, it will have to be controlled by the FIC, and not the PCM)
B A N N E D
so yeah a motor swap would be the easiest way of doing it
justin7779
12-25-2015 10:33 PM
