Q: Replacing break light
I just noticed the break light malfunction in my 2001 acura tl.
Is there a DIY replace break light page for Acura TLs ?
I'm not sure how many bulbs are there in TL's break light.
Any ideas ?
Also, Incase if anyone needs it, I noticed the following info thru google search.
Acura TL 1999-2001 -Generic Bulb Chart
Fitment Bulb Type Wattage Exterior
Front Headlight (Low) NA
Front Headlight (Hi) 9005
Front Turn Signal 1157
Front Bumper Light NA
Fog Lights 9006
Brake Light 7443
Reverse Light 921
Rear Turn Signal 7440
Rear License Plate 168
Interior
Door Lights 168
Dome Light DE3175
Map Lights 168
Center Console Light ?
Trunk Interior Light 168
Glove Box Light ?168/194
Any ideas ?
Fog Lights 9006
Brake Light 7443
Reverse Light 921
Interior
Door Lights 168
Dome Light DE3175
Map Lights 168
you should really just have to remove the plastic panels on the inside of the back of the trunk and pull the bulbs out. they should only be held in by some plastic screws or something. maybe i can grab a picture for you when i get home. i'm horrible at remembering though.
SSTS
SSTS
SatinSilverTypS
SatinSilverTypS,
I'm unable to remove the plastic cover (inside the trunk) completely
to reach the bulbs. One quick question. Should I have to pull the
plastic stuff on the yellow arrow or the orange one ? (Pls see the following pic)
trunk
Thanks,
Acura03.
trunk
Thanks,
Acura03.
No you don't touch any of that.
You have to remove the trunk cover then you can see them.
First you remove the plastic tabs(where there is an indent) and then the center plastic piece that runs across where the trunk latch is.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
rockyboy
Jan 25, 2016 06:00 PM
wusty23jd
Sep 24, 2015 11:41 AM
