Pully
Old Apr 2, 2008 | 04:23 PM
2ndgentl's Avatar
Pully
Ok, a pully for my 99 tl is only $20 from ssautochrome. Its the top pully on the passenger side. What does this do? Is it going to make a difference? And what makes the difference? Its only $20, easy bolt on.
Old Apr 2, 2008 | 04:33 PM
fsttyms1's Avatar
Dont waste your time or money on it. It wont do anything. The only pulley that does is the crank pulley
Old Apr 2, 2008 | 05:18 PM
bibledriver's Avatar
Something is missing...my
$20 bolt on should be one clue. Unfortunately, gains aren't cheap on your acura. For anything yielding a good gain you will for sure spend > $150.
Old Apr 3, 2008 | 08:21 AM
2ndgentl's Avatar
2ndgentl
The pully is for the power steering. Im assuming its a bigger pully.
Old Apr 3, 2008 | 08:25 AM
That would'nt be helpful at all. Don't buy it. Get a set (show and go) of Unorthodox Racing pullies off of the black market, or just the crank (go and no show) if you want performance gains.
Old Apr 3, 2008 | 10:03 AM
fsttyms1's Avatar
And what would that achieve? Nothing. There is no benefit from it OTHER than looks.
Old Apr 3, 2008 | 10:34 AM
pizz419's Avatar
Wish it was dropped.....
just take off the old one and sand/paint it and bam its "new" and cheaper than $20 + shipping.....
Old Apr 5, 2008 | 04:51 PM
3TL's Avatar
3TL
Correct me if I'm wrong. Installing light weight Unorthodox pulleys are just more wear and tear on your engine because our Acuras/Hondas do not have harmonic balancers. The only honda with a harmonic balancer is the prelude. Hence, my decision of not buying one. Like I said, correct me if I'm wrong.
Old Apr 5, 2008 | 06:26 PM
01tl4tl's Avatar
oh no not this discussion again!
Use search for the answer.
the lightweight pulley hurts nothing as proven by many ziners
Old Apr 5, 2008 | 08:11 PM
fsttyms1's Avatar
Your wrong. If it had a harmonic balancer and we removed it it would be more wear and tear. We dont have one. Our engined are internally balanced and have no need for one. You can install the pulley and have no adverse wear on the motor.
Old Apr 5, 2008 | 08:28 PM
MurkyRiversTL's Avatar
COTM Coordinator
You were wrong, and have been corrected
Old Apr 5, 2008 | 09:12 PM
01tl4tl's Avatar
3TL- you corrected info comes from our gen2 Guru- its the facts
UR makes a well known and trusted part
Some members here are using bomz- others the 20 buck alternative.
Its your motor- if the pulley fails, shatters- ------ so buy accordingly
dasuddith33
Aug 18, 2008 01:34 PM
ThinJim
Dec 12, 2007 06:54 AM
Nicky Pass
Aug 31, 2007 04:21 PM
cljosh
Dec 13, 2001 09:57 AM
