Performance chip
Old Feb 10, 2011 | 09:49 AM
dan lazer's Avatar
~~~ SKY'S THE LIMIT ~~~
Performance chip
so i was just looking around and i seen you can buy some kind of chip for 2g TL to get more horse power and torque--my question is----does anyone know if these actually work--also what about grounding kits---do they work to ???? thanks-----hey another thing-----i seen when people post and respond---on the bottom of there comment--theres a list of everything thats done to their car----HOW DO YOU DO THAT---thanks again
Old Feb 10, 2011 | 09:50 AM
no chips available for our cars.
dont waste your money.
Old Feb 10, 2011 | 09:54 AM
dan lazer's Avatar
ok thanks man
Old Feb 10, 2011 | 10:28 AM
03tLsNBP's Avatar
MechEng
the thing at the bottom of everyones post is called a signature. if you go to quick links, you will see an option for "edit signature"
also try and search before creating threads like this. this is the 23948985943rd thread about performance chips and a MOD will most likely just lock it up.
Old Feb 10, 2011 | 11:33 AM
01tl4tl's Avatar
see the diy threads for `intake resonator delete`- thats a free power mod!
also run tires at appropriate pressure,,not 32!! there is another free boost
run seafoam thru gas tank and manifold vac-
replace spark plugs if over 70kmiles on them, use only NGK Iridium or NGK Iridium IX
Do the egr port cleaning if over 70
that diy section will solve most probs, do some secret maitenance items, and performance will improve
Old Feb 10, 2011 | 03:56 PM
JDTL-S2002's Avatar
I installed my chip last week, got on it from a dig and nearly pulled the front end off the chasis!!! No but seriously, those chips are gimmicks and mess up your ECU....
Old Feb 10, 2011 | 07:42 PM
01tl4tl's Avatar
grounding kits can be DIY and do offer extra ground points for better electronic signals
Old Feb 11, 2011 | 11:42 AM
Rejckt's Avatar
Buy a bunch of 4 gauge cables and make your own grounding kit.
Old Feb 11, 2011 | 03:24 PM
kdawg8526's Avatar
13.2@106mph G37 RWD Sedan
what is the correct tire psi to have tires at. it says 32 on the door jam
how about 0 gauge wiring
Old Feb 13, 2011 | 04:15 PM
fsttyms1's Avatar
There is no real correct. 32 is whats recommended. Going higher (only to a point) will improve it. Going to high and you can wear tires to fast or exceed their max pressure rating. I typically run 38-42.
0 is overkill and 4 is more than enough. Grounding nearly more important than power.
Old Feb 13, 2011 | 06:14 PM
01tl4tl's Avatar
its the extra ground points on the engine parts- to a main solid good ground to chasis that makes it all work
one wire to each thing: ps, alt, engine block,- all to main ground point,,NOT the battery!!
tire psi depends on your tires rating- what max cold psi at what weight?
then figure the cars actual weight on tire- often ~80%
reduce that % from max and adjust a psi or 2 from there for comfort and wear pattern across the tire
example for those on low profile tires, max 50 psi, 80%actual weight-
subtract 20% /10 psi = 40
Old Feb 14, 2011 | 12:32 PM
rcb2000's Avatar
please a 4 guage cable for additional ground what a major waiste of effort and time.
Old Feb 14, 2011 | 01:19 PM
fsttyms1's Avatar
Why is it a waste? Grounds are proven to work. In fact there was a dyno a few years back from a member that gained from it.
Old Feb 14, 2011 | 01:38 PM
rcb2000's Avatar
gained what a 1/4 of one horse power by having better grounds, please not going to happen, hotter spark isn't going to occur, more fuel isn't going to happen no bennies what so ever just a bunch of hype BS
Old Feb 14, 2011 | 07:06 PM
Karanx7's Avatar
Unregistered Member
I have to replace my battery cables, according to the dealer. How much would that normally run if I did it myself with OEM parts? Also, does a grounding kit add more cables, or replace the current ones?
Old Feb 14, 2011 | 07:57 PM
01tl4tl's Avatar
ground cable kits adds 4 more cables run to a central plate mounted to a frame rail- does not replace any of the oe cable setup
There is better signal for the electronics and slight gains to be had
will it save the world- no, but any bit of mileage you can eek out helps as gas gets ready to pass 5 bucks a gal this summer
dealer wants your first born child in exchange for the cable install!!
buy your own at parts store and get busy
Old Feb 14, 2011 | 09:30 PM
fsttyms1's Avatar
My motor ran MUCH smoother adding them. Go blow smoke up someone else's tail pipe.
Old Feb 15, 2011 | 09:19 AM
Rejckt's Avatar
I grounded my car, cost me $35-$40 or so. It's not really about horsepower imo, my car ran much smoother and idled a bit better after grounding it. But I live in a place where the sanitation department sprays salt on your car for fun.
Plus do your $ / HP ratio.
SC $4000 = 40 HP = $100 / HP.
If you gain 1 or 2 HP by grounding = WIN.
But srsly, you probably can't feel the HP, but it does run smoother.
Old Feb 15, 2011 | 09:26 AM
03tLsNBP's Avatar
MechEng
any DIYs or write ups for grounding kit?
Old Feb 15, 2011 | 09:30 AM
take off old grounds, replace with bigger gauged ground.
its called the big 3, because there are 3 main points.
Old Feb 16, 2011 | 01:05 PM
rcb2000's Avatar
funny how it went from increased horse power to a smoother idle sounds like your blowing the cow pies around.
But yes a single ground from the block to the frame/body would be all that is need to provide a better all around ground, but you'll never see or feel any difference either way if you add it or not.
Old Feb 16, 2011 | 05:15 PM
Rejckt's Avatar
Doesn't hurt to invest $35 into your car. I felt a difference... But then again, my grounds were corroded
Old Feb 16, 2011 | 09:54 PM
fsttyms1's Avatar
I didnt say mine added power because I didnt dyno it. But I could tell it ran smoother. It very well may have added a hp or 2 but no one could ever notice that. So no, its not me, its still you doing the blowing.
Old Feb 16, 2011 | 10:56 PM
Karanx7's Avatar
Unregistered Member
Fsttyms1, it's impressive how much crap your willing to take.
How did you get that PS button with the link to your profile?
Old Feb 16, 2011 | 11:00 PM
03tLsNBP's Avatar
MechEng
Hes a Mod. He can do anything.
Well not anything, only Ron A can do anything. Ron A could even make a PS pop out of your computer screen.
Old Feb 17, 2011 | 07:03 AM
totaledTL's Avatar
Was it smoother at idle, or are you saying it was smoother at any rpm? Was it during a time there was increased electrical load, i. e., headlights, seat heaters, rr defrost, etc.?
Old Feb 17, 2011 | 06:35 PM
fsttyms1's Avatar
Idle for sure, power just seemed smoother more linear. Recently did it on my ice racer (90 prelude) as well and noticed a big improvement with the motor running (as far as smoothness went)
Old Feb 17, 2011 | 06:37 PM
fsttyms1's Avatar
Why? Its not my job to ban people for things i dont agree with. Sometimes thats what happens in life, you dont always agree with everyone
Its under your settings, edit details.
Old Feb 20, 2011 | 08:18 AM
Oakroadsteve's Avatar
I have read a bit abou seaform over the years...I have 110K on my TL. Can you advise what are the benefits of this product?
I have found the "search feature" to be finicky. What is an egr port cleaning?
Sure would appreciate some detail........
Old Apr 9, 2011 | 08:58 PM
BigVIn89's Avatar
9th Gear
Has anybody ever tried "GforceChips". My boy was telling me about it but I wanted to do some research on it before I bought it...
Old Apr 11, 2011 | 11:11 PM
Rejckt's Avatar
Go buy it and tell us how it goes. I doubt anyone here has anything besides neo/emanage/fic
Old Apr 12, 2011 | 03:25 AM
Skirmich's Avatar
Cool
I Ran 2AWG for my Big 3 so im in the Sweet Spot
I also Changed the Starter Cable since it seems out of place in my Shiny Positive Volt-E-Meter Post so I fondly call it "Big 4".
Main reason was for AUDIO Gear I didnt feel any improvement in Power or Idle, but the car Started seriously better in a matter of a Cold and Precise Second no More cranking sound just a flip of the key and we are good to go!
Old Apr 13, 2011 | 03:21 PM
HairyMonkey019's Avatar
can we get some DIY's for this stuff?
i'm really interested
Old Apr 14, 2011 | 10:46 AM
Rejckt's Avatar
Rajca has a diy
Old Apr 14, 2011 | 02:59 PM
do u have the link to the DIY?
Old Jun 3, 2011 | 10:15 PM
caborik's Avatar
i purchased my g-force chip and installed it yesterday.i am monitoring my gas mileage and will post results in a couple of weeks.i have a 1996 tl 2.5,the chip cost 69.00 plus shipping.
Old Jun 3, 2011 | 10:20 PM
in for results.
Old Jun 4, 2011 | 09:51 AM
03tLsNBP's Avatar
MechEng
in for results
Old Jun 4, 2011 | 10:00 AM
hANDYcaptd's Avatar
It's the Halladay season!
This I've got to see.
Old Jun 4, 2011 | 08:57 PM
JterrorC's Avatar
Always a Honda =Þ
going to high ..will wear your tire....wtf..never knew that one
70 to see your mpg...ehhhh..anytin else?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
San Yasin
Sep 29, 2015 10:52 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
