P2r
Old Oct 24, 2010 | 10:03 AM
westhaventl's Avatar
Moe T
P2r
So I tried searching and couldn't get a solid answer. I was gonna order the throttle body gasket, intake manifold gasket, and throttle body spacer. Is it even worth my time to do? Any difference? I have no intake but do have comptech filter
Old Oct 24, 2010 | 12:01 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
It's worth the time if you do the TB coolent bypass at the same time.
You might not feel actuall hp gains but it will help hp loss from the heat.
on hotter days you car will fell more predictable with throttle response since those mods are cooling the intakes air.
Now if you do the lower temp fan switch,lower temp thermostat,and a 1.3 radiator cap at the same time with what I desrcibed above you will feel a gain but, Like I said you will it because the cooling mods are to reduce losses in power from the heat.
If you installed these in the summer and you been driving it for a couple months so you new how lazy your car felt. You would be able to tell the difference for sure.
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
ryanfett
Oct 29, 2015 06:01 AM
obert
Sep 3, 2015 08:40 PM
