oil
oil
hey guys,
i just purchased an 03 tl type s and love it. what do you all suggest to do:
go to the dealer and get oil changes there
or
go somewhere else, like a jiffy lube, and get it changed there.
also, what kind of oil do you all suggest?
thanks,
tex
or
thanks,
tex
Do it yourself. By far the easiest car I've ever had to change the oil on.
Lot's of good choices in oil. I'd go synthetic.
Mobil-1 or Amsoil are a good start.
And get a good filter. The OEM Honda/Acura filters are sub-par. Napa Gold, Wix, Donaldson are all good ones.
SSTS
I was going to change my oil myself. The dealer has always changed it for the original owner. My question's are Mobil 1 or GTX (not synthetic)? Use Acura filter, Fram or Fram extended guard?
On all my other cars I changed oil every 3 to 5 K with GTX (non synthetic) and Fram flter not the extend guard.
If I use Mobil 1 how often do you change it? Does synthetic make a big difference?
Bottom line what is the best result to go and how often changing it?
Thanks,
Andy
Thanks,
Andy
Originally Posted by Delirium
Yes did use it once,but now i'm using the S2000 filter, a little bigger then the tl ones.Bought them at honda.
M1 extended performance filters are awesome filters, along with M1 extended performance full syn is awesome oil. the TL is very easy to do oil change, but my wifes 98 corrolla is easier, so easy I think I'll teach my 9yrs old nephew how to do it. trust me, extremely easy to change your own oil.
Originally Posted by OntarioTL
So what makes the S2000 filter better than any other Honda filter besides size?
I'm not sure if they make it to fit the TL, but Wix (or carquest) makes the best "everyday" oil filters for cars, way ahead of Fram or K&N.
As for oil, go with a good synthetic like Mobil 1 or Redline - if you use the right oil, you may pick up about 5hp from less friction and reduction of windage (extra oil on the crankshaft).
high priced filters are all over rated . I used the cheap fram filters for the 1st 100k then switched to the extended guard for the 2nd 100k because i went to 15k intervals. My motor was still in perfect shape and dont see the need for expensive filters on these motors. You can still see the original cross hatching in my old motor
Originally Posted by Texas TL Type S
Thank you all so much for your help. I am going to get this done at the dealer this time, just because i really need to get it done. but next time, i am doing it myself!!
you guys have been very helpful.
Originally Posted by sbuswell
changing oil is like changing baby diapers it is messy but very easy.
IBankMouse
06-13-2020 12:53 PM
