no cat
Old Apr 5, 2009 | 02:29 AM
thinhthan's Avatar
no cat
ok im about to register my car where they dont require emissions. would i get more power if i went with a straght pipe instead of a cat or should i just leave it?
Old Apr 5, 2009 | 08:20 AM
fsttyms1's Avatar
Just leave it.
Old Apr 5, 2009 | 09:20 AM
thinhthan's Avatar
ok
Old Apr 5, 2009 | 10:54 AM
Rajca's Avatar
wham bam thank you ma'am
leave it or get a more free flowing cat.
Old Apr 5, 2009 | 11:47 PM
thinhthan's Avatar
where can i get a high flow cat at
Old Apr 6, 2009 | 04:51 AM
Rajca's Avatar
excelerate for one that bolts up or online that u have to weld in
Old Apr 6, 2009 | 08:29 AM
EL19's Avatar
i have a str8 pipe no cat and it has more power but it has to be custom made. If you didnt wana go thru the hassle just leave it.
Old Apr 6, 2009 | 10:08 AM
fsttyms1's Avatar
^ you also get a lot of rasp from the exhaust without it.
Old Apr 6, 2009 | 10:15 AM
EL19's Avatar
this is tru, close to redline u can hear the "rasp" lol...other than that the exhaust note hasnt changed. I used to pretty thick steel for my exhaust tho and have a huge magnaflow resonator
Old Apr 6, 2009 | 10:35 AM
Neejay's Avatar
I don't have a cat on my 240sx...and I get tired of smelling exhaust fumes.
As stated, hi-flow or leave it. I'm not even sure it's worth the extra $$ to buy a hi-flow.
Old Apr 6, 2009 | 11:52 PM
adamlee05's Avatar
Thread Police Chief
Originally Posted by Neejay
I don't have a cat on my 240sx...and I get tired of smelling exhaust fumes..
That's not caused be removing your cat...most likely a small exhaust leak
Leave it or Hi-flow. If you remove it you'll have to loop the O2 sensor to not throw a code, and you'll also lose low-end torque because of a loss of back pressure. The gains of removing aren't worth it really. Just my
Old Apr 7, 2009 | 12:35 AM
thinhthan's Avatar
ok im prob not gonna take it off maybe just get a high flow cat
Old Apr 7, 2009 | 01:02 AM
adamlee05's Avatar
Thread Police Chief
Old Apr 7, 2009 | 03:05 AM
tiblanc_lebrun's Avatar
I use a 2.5 inch hi flow cat from magnaflow and is great
Old Apr 7, 2009 | 05:12 AM
Neejay's Avatar
huh? No cat = no filtration = fumes. I don't have a leak. I mean, yeah, the only time I get them is sitting still (depending on which way the wind is blowing).
Old Apr 7, 2009 | 07:28 AM
Rockstar21's Avatar
The Dumb One
huh? 2 of my cars = no cats = no fumes
maybe look a little closer?
i agree it doesnt filter... but the exhaust should still be leaving the rear of the car and not coming up from underneath to where you can smell it..
Old Apr 7, 2009 | 07:39 AM
fsttyms1's Avatar
No, with the cat gone the exhaust does smell and its not from a exhaust leak.
Sorry, but i would have to say then your nose doesnt work. Every car i have taken one off of the exhaust smells stronger, ive been asked if i had a leak with mine off the TL because of the stronger smell.
And what do you think the cat is if you think its not a filter? Its intended job is to convert harmfull exhaust into something not so harmful. Sounds like a filter to me.
Old Apr 7, 2009 | 08:00 AM
Rockstar21's Avatar
The Dumb One
i said "i agree, it doesnt filter" because he said without a CAT it DOESNT filter....
i could say the grass was green and youd set out to correct me.. whats the deal?
and yea, i can smell stronger exhaust.. when im standing behind a running car.
Old Apr 7, 2009 | 08:19 AM
Rockstar21's Avatar
The Dumb One
so let me make this as clear as possible..
im not doubting the FACTS of what cats do.
im saying that without a cat, if you sitting at idle and smell fumes in the cab. you might either have some crazy winds.. or a small exhaust leak.
i've run straight pipes on 2 cars and you can only smell anything when standing behind the car. also rasp is an issue, but if you have an aggressive exhaust it would muffle it out for the most part..
yes, the cat is a filtration system for the exhuast
Old Apr 7, 2009 | 11:29 AM
fsttyms1's Avatar
Sorry i miss read it. And your right i would correct you. My grass isnt green, its still brown yet!
Old Apr 7, 2009 | 12:23 PM
Rockstar21's Avatar
The Dumb One
damnit i knew there was a loop hole on the grass... shoulda went with the sun being hot...
Old Apr 7, 2009 | 11:39 PM
adamlee05's Avatar
Thread Police Chief
I'm with rockstar on this... have experience with many cars with cat-deletes and no exhaust fumes in the car.
I guess its a car-to-car thing
Kris....you have grass? I figured you're entire yard would be one giant auto-cross course
Old Apr 8, 2009 | 01:22 AM
The cat is just a "filter" that burn the unburned engine fuel. When you start the car your exhaust smelt like fuel and it have no smell when the cat come in is normal temperature. Some car that have probleme to have a complet combustion can have a air pump that blow air in the cat that help to burn fuel that go in the exhaust.
Old Apr 8, 2009 | 01:12 PM
niju321's Avatar
the catalytic converter catalytically converts things like nitrogen oxide to things that aren't so bad for the environment, its not an afterburner lol
Old Apr 8, 2009 | 01:26 PM
fsttyms1's Avatar
We arent saying because you remove it you will smell it in the car, Of course you shouldnt smell it in the car (like driving). But normally the exhaust is cleaner and you dont smell it, but without the cat wind blowing the right way while sitting still or walking around the car outside you can smell the difference.
Yes i have grass, my yard isnt big enough for the car, though my 4 wheeler and Nitro RC Truck do a # on it
Old Apr 8, 2009 | 05:33 PM
Neejay's Avatar
I still say leave it or get a hi-flow. Nothing more to say
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
DerrickW
Nov 15, 2015 05:52 PM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
