Loss of Power Due to CAI
I was told by a friend, than any CAI will create a "lost" of power in the TL-S. The air takes longer to suck into the engine which puts a "delay" on the response of the car.
I wanted to know if you guys think that, that is true or false.
Have you ever seen the length of tubing that the air has to travel thru with the stock system? It doesnt end at the air filter.
And to answer your question NO it doesnt loose HP It gains it.
-Arsenic-
Knock it off guys. STAY on topic
Not sure about other brand but for Comptech IceBox, the path the air takes is very short. Besides, the IceBox has an air scoop at the bottom which forces air to flow a lot quicker. I have IceBox on my TL-S for years now and so far I did not feel any power lost.
Just my $0.02
Just my $0.02
6G TLX-S
Originally Posted by JDM96specCTR
usually when putting aftermarket intake, header, exhaust, etc.., it shifts your powerband higher. meaning u will lose some power at lower rpms, but gain at higher.
Former Sponsor
Absolutely correct. CAI adds more flow. More flow hurts low end power. So there won't be any power gain, but even slight loss of power at the lower rpm band. Small gain at the mid band, and maximum gain at the uppermost band. Venders always quote this peak power value for their intake/exhaust products, but they never specify that it only happens at very high engine rev. Only increase engine displacement or forced induction can add solid power to the low rpm band.
Thanks u guys, i guess my question has been answered... But i may also be asking the wrong question. From what u guys have said, CAI will Gain Mid HP and High end HP. He has an IS300...
He says that my car has more torque than his which i don't doubt, cause she (my car) can really move off the line. I guess the question is not a loss in power, but a loss in torque.
Will there be loss in torque due to the CAI?
Originally Posted by Excelerate
While the info stated above is generally true, most vendors do include dynos with their intakes so you can see where hp gains are. They don't hide that info.
This is a (6 speed) with the ice box dyno.
No loss in power at all
http://www.comptechusa.com/store/med...spd_icebox.pdf
Former Sponsor
higher compression and aftermarket cams will also add bower throughout the whole powerband. unfortunatly theres nothing like that available for these motors off the shelf
but you have to pay attention to what the dyno really is. many of the dynos that companies show are not on stock motors, sometimes there are ALOT of other mods to the motor, which usually will yield greater gains for another single mod. for example, say i have a motor that has headers, exhaust, pulleys, lightened flywheel and stock intake.. now if i add a cold air intake, its going to yeild a far better gain over the stock intake, than if it were on a stock motor. you just have to pay attention when it comes to those "advertisement" dyno graphs and get all the info.
