Light Weight Battery, anyone have one?
Found this, hope it'll help ppl in the future
http://www.freshalloy.com/forums/sho...d.php?t=168999
As far as I know - All the CCA for the manufacturers is done at 0F, and the CA is at 32F, all this info is off the manufacturer website.
READ THIS:
In BLUE are the brands whose CCA Ratings seems either off or make it hard to find their testing methods.
Deka Batteries are more than likely to be Deka ETX rebadged -- Their advirtised CCA IS PROBABLY NOT PERFOMED AT 0F.
By Brand:
Braille**:
Braille B3121 ----------CCA: 550 ---- weight: 21lb ---------------- CA: 742
Braille B2015 ----------CCA: 425 ---- weight: 15lb ---------------- CA: 574
Braille B14115 ---------CCA: 360 ---- weight: 11lb,8oz ------------ CA: 486
Braille B106 -----------CCA: 210 ---- weight: 6lb,6oz ------------- CA: 283
Westco:
Westco Miata ---------CCA: 475 ---- weight: 25lb
Deka:
Deka ETX30 -----------CCA: 370 ---- weight: 21.7lb
Deka ETX20 -----------CCA: 270 ---- weight: 15.5lb
Deka ETX18 -----------CCA: 300 ---- weight: 18lb
Deka ETX16 -----------CCA: 275 ---- weight: 17lb
Deka ETX14 -----------CCA: 200 ---- weight: 12lb
Deka ETX12 -----------CCA: 180 ---- weight: 9.4lb
Deka ETX9 -----------CCA: 120 ---- weight: 6.3lb
Odyssey:
Odyssey PC680 --------CCA: 220 --- weight: 15lb / 16lb For MJT*
Odyssey PC925/MJT ---CCA: 380 --- weight: 24lb / 26lb For MJT*
Optima:
Optima 34&34R --------CCA 800 -----weight: 37.9lb --------------- CA: 1000
Optima 37/78 ----------CCA 800 ---- weight: 38.8lb --------------- CA: 1000
Optima 75/25 ----------CCA 720 ---- weight: 33.1lb --------------- CA: 910
Optima 25&35 ---------CCA 720 ----- weight: 31.7lb --------------- CA: 910
Duralast:
Duralast 8AMU1R ------CCA: 330 ---- weight: 25lb
Marathon:
Marathon MAR-8AMU1R-CCA: 320 ---- weight: 25lb
By CCA:
Optima 34&34R --------CCA 800 -----weight: 37.9lb -------------- CA: 1000
Optima 37/78 ----------CCA 800 ---- weight: 38.8lb -------------- CA: 1000
Optima 75/25 ----------CCA 720 ---- weight: 33.1lb -------------- CA: 910
Optima 25&35 ---------CCA 720 ----- weight: 31.7lb -------------- CA: 910
Odyssey PC925/MJT ---CCA: 380 ---- weight: 24lb / 26lb For MJT*
Odyssey PC680 --------CCA: 220 ---- weight: 15lb / 16lb For MJT*
By Weight:
More info:
Braile:
Probably Deka rebadged
**no info on website on what Temp the CCA and CA test are done at...
DEKA:
Come with M6 Thread on terminals - you will need adapter to SAE automotive Terminals.
Rebadged as BigCrank, Braille and other brands // BigCrank has cheap price .
(Proved and discussed on the vwvortex there is a whole thread about it.)
Odyssey:
*MJT: Metal Jacket + Terminals.
Also the Odysseys have battery mounting brakets avaible.
Miata Battery:
Duralast rates them at 330CCA, Marathon at 320CCA, Westco at 475CCA,
make what you want of this info but personally I'm not getting a Westco Battery
Made by EastPenn Mfg.
Sold under:
Marathon MAR-8AMU1R (1Year Warranty)
Westco 12V31M (4 Year Warranty)
Duralast 8AMU1R (8Year Warranty - apparently WAS avaible at autozone)
READ THIS:
By Brand:
Braille**:
Westco:
Deka:
Odyssey:
Optima:
Duralast:
Marathon:
By CCA:
By Weight:
More info:
Braile:
DEKA:
Odyssey:
Miata Battery:
Sold under:
mada51589
05-03-2022 08:54 PM
HeloDown
09-08-2015 06:51 PM
