Labor costs for headers/springs?
Old Nov 28, 2006 | 09:19 PM
gc86's Avatar
Advance
How much did you get charged for your header and or spring install? If your in the bay area that's a plus
Old Nov 29, 2006 | 06:41 AM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
i can't remember the exact price but it was in the ballpark of $70 an hour x 6 hours of labor on my last car. i did my TL myself so it was nice and free
SSTS
Old Nov 29, 2006 | 11:16 AM
drcookie's Avatar
I did the header installation myself and it took me about 5-6 hours to complete.
For professional, my guess is they would take around 4 hours. Depending on the hourly rate they charge, you could do the math.
I have no idea on spring installation.
Good luck.
Old Nov 29, 2006 | 11:42 AM
gc86's Avatar
Advance
Damn... I think im going to have some nice install weekends this holiday.
Old Nov 29, 2006 | 12:06 PM
fsttyms1's Avatar
Both are extremly easy to do and dont require fancy tools. You can rent spring compressors/buy them for like 30 bucks and do it all yourself in your own driveway. There are DIY's on those things on this forum. You could complete with a friend both in less than a day
Old Nov 29, 2006 | 12:29 PM
gc86's Avatar
Advance
I wouldn't say extremely, i've heard horror stories with cat bolts that won't come off for shit. Anyone want to help me with header install this weekend?
Old Nov 29, 2006 | 12:45 PM
fsttyms1's Avatar
well if your any bit mechanically inclined and dont give up they arent that hard.
Old Nov 29, 2006 | 12:53 PM
gc86's Avatar
Advance
Im a graduating ATII technician at Sequoia Institute
Old Nov 29, 2006 | 01:11 PM
fsttyms1's Avatar
well then shouldnt be a problem right
Old Nov 29, 2006 | 02:11 PM
type-s09's Avatar
13.2@ 107 on Street tires
it took me 2 hours to install my headers..no problems..and 2 1/2 to install my springs...if you can put a tire on you can put a header on...just takes patience
Old Nov 29, 2006 | 03:00 PM
fsttyms1's Avatar
Old Nov 30, 2006 | 01:59 AM
gc86's Avatar
Advance
2 hours?? that's pretty fast, you didn't run into any tough bolts? was someone else helping you?
Old Nov 30, 2006 | 11:44 PM
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
thats fast but if you know what your doing and so does your assistant it would not be too hard to do in 2 hours.
having a good lift and the right tools
dont forget a leverage bar/breaker bar
Old Dec 1, 2006 | 01:15 AM
drcookie's Avatar
What year is your TL? If yours is 2002 and newer, you should not have a lot of issue on the cat bolts. Those people that were having problem because they live in a snowy place where salt from the road has rusted the bolts pretty bad.
I live in Bay Are and I managed to get my off fairly easily. Still ... they required some force.
Old Dec 1, 2006 | 02:17 AM
gc86's Avatar
Advance
I see.... well I guess im going to tackle this myself than i've never looked under the car indepth, do I have any space to work with on the rear headers? what size breaker bar should I invest in? im going to need to buy a new jack also since the 20yr old one I have now can't get the car that high into the air.
Old Dec 1, 2006 | 04:32 PM
drcookie's Avatar
A good floor jack and jack stands should do the lifting job. I have Sears 3-ton floor jack and jack stands which I bough 4-5 years ago and they work grreat.
Removing the headers will be one thing. The stock headers are easy to be removed out from engine bay. Putting the new headers in would need some creativitiy. Since the after market headers tend to be "larger", you need to be patient and be creative on how to "insert" the each header into the engine bay. I scratched up both my headers when I was putting them in .
I would recommend a torque wrench as well since you need to properly torgue the bolts on the header to the engine block.
Hope this helps.
Old Dec 1, 2006 | 05:23 PM
gc86's Avatar
Advance
It does, thanks a lot.
Old Dec 5, 2006 | 02:51 AM
gc86's Avatar
Advance
Update guys, installed the headers tonight, toke me around 5 hours total with cleanup/testdrive etc. my question is though, where can I buy an extra set of gaskets for the megan headers. I need the 2 manifold to downpipe gaskets and the downpipe to cat gasket.
Old Dec 5, 2006 | 08:06 AM
CL Platano's Avatar
Tristate ViP Crew
Call them it will cost you about 25 bucks that's what I did and I got a set of gaskets and brand new bolts.
Old Dec 5, 2006 | 09:50 AM
Sushiplease's Avatar
SLOW TL
Thumbs up
It's always nice to see someone who was going to pay someone to do their dirty work, do the work themselves. Great job...
Advance auto parts or any car auto shop carries gasket makers. I perfer these... Cheaper and you can use it to make more then 1 gasket...But I wouldn't use this for the header gasket, only for the pipes!
To me, a car isn't mines unless i do my own work...
Old Dec 5, 2006 | 11:30 AM
drcookie's Avatar
Congratulation. You have made it.
5 hours is not bad at all consider you have to go slow and some of the bolts are pain to get to. Any resonance so far?
As far as the gaskets go, you could either call them up or bring your sample (broken gaskets) to NAPA auto store. There is one in Morgan Hill and the staff is very helpful. They might be able to find them in stock or they could order them for you.
Cheers !!!
Old Dec 5, 2006 | 12:51 PM
gc86's Avatar
Advance
Hahaha, thanks guy. It wasn't hard at all, all it is is bolts and I figured im going to be doing this on a daily basis come January. It's just time consuming, especially the rear header. Thanks for the comments, i'll probably use the RTV since that looks like the quickest fix without spending 25 bucks. I need to go get the first flexpipe fixed though since it has a NASTY leak, and people say that gets rid of the resonance. We'll see, thanks again everyone. Happy Holidays
Old Dec 5, 2006 | 01:14 PM
CL Platano's Avatar
Tristate ViP Crew
your best bet is to cut that first flex pipe and put a straight pipe because you'll constantly have an issue. I'm on my 2nd pipe right now and my car sounds like a helicopter because I scraped the hell out of this pipe.
Old Dec 5, 2006 | 02:41 PM
gc86's Avatar
Advance
^^ I just got that done. I already bought gasket maker, now I just need to take off the downpipe and apply it. Hope it seals everything up.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
