Jet Hot Coating
I have Jethot's Sterling silver on my Comptech header, stainless steel will rust if left unprotected due to exposure to high temperature. Exhaust gas also exits faster at higher temperature, yield slightly better flow.
everybody i've talked too on this forum and other import car forums have reinforced that it's really not going to get us any gains for our particular engines. it's more geared towards headers on big block v8s that run at much much higher temperatures. it's doubtful you would be able to measure any efficiency increase, although i won't say it's impossible.
of course that doesn't mean you shouldn't get it done for environmental protection, although TunedTL, i don't think you need to worry about SS rotting very quickly. it will happen over time but it should take significantly longer than the regular metal the stock exhaust pipes are made from.
SSTS
SSTS
Originally Posted by NSXNEXT
Well I do believe there are some heat reducing properties in the coating so...
cooler engine bay = cooler engine = slightly better performance
it would be interesting for someone to try though. get some flow readings and dynos.
SSTS
jjkilgallon,
Yes, I fedex my header to Jethot west coast address. I believe it is in Arizona.
SSTS,
I am sure SS will hold up better than cast steel, but Comptech header is known for discoloring after a few thousand miles. Take a look at a picture I stole from a black market sale of an used Comptech.
Here you see the mounting plate to the engine is already begin to rust, the pipes are discolored due to heat stress. With Jethot coating, you maintain the original sterling silver or black.
Not that it is important for everyone, but some may want better look considering spending >$1000. They want to pop the hook and not have a rusty, discolored look.
It is also not cost effective to run a dyno for a $120 coating. Like NSXNXT said, it reduces heat in the engine bay because exhaust gas radiates heat. This quote from BMW forum, understand M3 has a different engine but it is still V6. Gas can be as hot as 1000 degrees F
I already mentioned the 3rd benefit, of keeping exhaust gas hot, as hotter gas exist faster, which equal to lower backpressure.
Afterall, it depends on what you want, would coating give you what the gain of UR pulley, no. But am I satisfied with the result, yes.
SSTS,
Did you know that our engines have temperatures in this range (F)?:
Upper Cylinder Wall 300-500
Exhaust Valve 1200-1500
Piston Crown 700-800
Hydraulic Valve Lifter 250-300
Crankcase 200-300
Top Piston Ring 300-650
Exhaust Gases 500-1000
Combustion Chamber 3000-5000
Coolant Jacket 165-230
Connecting Rod Bearings 200-375
Main Bearings 200-350
Crankcase 200-300
Originally Posted by CleanCL
increase in temperature will results in increase in velocity... i think. this is one of the more understated benefits to doing these coatings. i am going to try coating my whole exhaust, i'd like to see what happens.
Jethot coats inside and outside the exhaust pipe/header. However, I am not sure they can coat resonator and mufflers. I believe after the cat the temperature drops significantly, performance and rust preventing benefits may not justify additional cost. But just like any mod, it is a personal choice.
i got this information from an enclosed pamphlet jet-hot sent to me directly:
"Headers aren't the only parts that benefit from Jet-Hot coating; it can also be used on exhaust pipes, mufflers, and even (for emissions-reducing quicker light-off times) the catalytic converter. By applying Jet-Hot only to the top and bottom intake manifold surfaces, as well as the other outer surfaces of turbocharger ducting, centrifugal supercharger ducting, and fuel-injection system air-intake tracts, you can keep incoming air and fuel cooler by insulating the charge from radiatn engine-compartment head."
i plan to send my cat and intake manifolds sometime this year.
I've heard great stuff about High Performance Coatings or HPC.
They're widely involved in motorsport.
Some of their racing milestones.....
14 - Indy 500 winners
14 - Daytona 500 winners
4 - NASCAR Winston Cup Championships
10 - CART Championships
2 - IRL Championships
5 - 24 Hours of LeMans wins
9 - 24 Hours of Daytona wins
18 - NHRA Top Fuel Championships
5 - NHRA Top Fuel Funny Car Championships
13 - NHRA Pro Stock Championships
15 - NHRA Pro Stock Bike Championships
World's fastest wheel driven land speed record vehicle
World's fastest piston driven land speed record vehicle
World's fastest small block powered land speed record vehicle
World's fastest Unlimited Air Racer
First 4-second NHRA Top Fuel Dragster
First 300 MPH NHRA Top Fuel Funnycar
First 200 MPH NHRA Pro Stock Car
First 6-second NHRA Pro Stock Car
First 6-second NHRA Pro Stock Motorcycle
Check their site out. A great read.
www.hpcoatings.com
www.hpcoatings.com
MrHeeltoe
20
Feb 23, 2023 01:54 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
