I need help, swap questions...
I'm doing the cl-s 6 swap; motor and transmission. I have the wring harness from that engine too now i have two things stoppin me from putting it into the car...
1- I might be stuck with out the cl-s 6 ecu which would really suck cuz I wouldn't have the raised RPM's. Since mine is a 99 tl-p not sure what i should do... whether or not to get a type s ecu for best results or what could help cuz most are running the cl-s6 ecu (minus phee)
2- When i was checking everything out i discovered the flywheel was pretty much gone, way too much free play (almost solved this one- Already purchased the Clutchmasters Stage 1 kit with an aluminum flywheel)
3- Going to school and work everyday really doesn't give me too much time to play around with this so its dragged on for almost a month now. =/ i wanna drive it already.
4- I's also putting in a few more goodies; a high flow cat (xcelerate) , xs headers (off richiev6), comptech ice box. Which is taking me a to get the money for all this. but might as well since i have everything apart.
can anyone help me out here, what should i do about the ecu? I have pretty much everythin off the cl except for the ecu (including the under dash harness)
Jul 16, 2017 07:33 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
