How to run amplifier power wire to battery through firewall (Acura 2003 TL)?
Hi - Thanks for your help in advance.
I have a 2003 TL (4 dr) and I just bought a sub woofer amplifier. I need to run the 12 AWG power wire (Red) to the battery positive terminal in the engine compartment. I have to do this through the firewall from inside of the car to the battery. I prefer NOT to drill a hole through the firewall. I'd appreciate your thoughts/advice.
Thanks,
tham1226.
Thanks,
tham1226.
if ya get on yer knees with a flash light----look under the driver side down by the pedals
you will see a little circle black plug-----its by the gas pedal-----that pops out and u run the power wire through there
thats how i did mine------and i ran the power under all the kick panals too
good luck and let us know how ya made out
Thank you Dan. I found the rubber plug and will work on it this weekend. I think, if I can, I'll drill a hole through the rubber plug and feed the power wire through so the wire will be surrounded by the rubber and not the metal chassis. I will let you know how it works out.
Thanks again,
Tham.
Thanks again,
Tham.
Definitely drill hole or make a small slice. Don't run it through the hole n try and smash Plug back in there. It'll rub through over time n ground it out. A trick to help fish through also is tape the wire with electrical tape to a straightened out metal hanger and help feed it through.
Goodluck!
Goodluck!
Thanks again,
Tham.
Thanks again,
Tham.
yea thats actually what i did to be honest with ya----i took it out first and sliced a lil slit in it then put it back in----then just pushed it threw
but yea good luck
thats funny ive done mine the same also the hole is great for sub wire i ran a 0 gauge through it, although i didnt find the rubber from inside what i did was take the splash gaurd off the drivers side and locate it u can see another rubber right next to it with the hood wire feed, easy way to take it off is use a flat head and push it in, i noticed some said don feed it that way but ive had mine like that for a good year and a half and no problems.... good luck
^^ I dont understand the question? You mean for the +12v Lead from HU to AMP? If you have an Aftermarket HU is pretty easy..
If you dont and you are still riding the OEM HU there is a +12v Lead on the Subwoofer AMP behind the passenger seats.. Tap it and you have your lead.
U should get a rubber grommet. U dont want to sum how slice open ur 12 guage n short anything. And u should upgrade to at least 4 guage. 12 is ok but if u ever plan on swapping out ur speakers or amps or upgrading, ur not giving enuff juice to fully power it all up. But if u plan on staying within the 600w range, then I guess its fine.
Im not understanding that question neither but if u have aftermarket amp n hu, u just run the remote wire frm hu to the amp. But if u have oem hu with aftermarkert amp then u can power up your amp by by wrapping one end of ur remote wire to the acc fuse. Then run it to the amp then u have power to ur amp. But key to all the wiring is a good ground. Make sure u have a good ground!!
I have an 04 TL 6 speed manual. I'm trying to get power to my new sub and amp. I have no rubber grommets. I do have a white plastic grommet above the gas paddle, but there's metal behind it with what looks like a small post with threads. Any idea how I might get that out to run power cable to the battery?
mada51589
Jan 9, 2025 04:40 PM
Soul_Deamon
Nov 13, 2018 04:44 PM
it barely went trough.
