High Flow Cat w Headers??
My 01 CLs has headers and I read in some of the posts a ways back that a high flow cat is a good compliment.
I run a stock exhaust but like the idea of adding a few hp to the equation via a more efficient cat.
Can anyone indicate if the hp gain is worth the cost? I would like to see a 5 horse gain on the mod....
you wont feel 5 hp
why are you postng in the TL section? try the CL area --
even though same car many CL ziners are into performance parts
kill you till you die
Really you should upgrade the exhaust if you want to upgrade the cat, there's no point in putting on a high flow cat and choking exhaust flow with the stock piping and mufflers. I would suggest a test pipe or cat with the same OD as your headers collector and run a 2.5 inch exhaust. If the cat throws an O2 code you can get a piece that raises the sensor higher off the cat so it reads differently and keeps your CEL off.
Former Sponsor
http://store.excelerateperformance.c.../i-494447.aspx
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
