Which Headers Are Best
Ok so I was wondering if someone could tell me which headers are the best for under $110 before shipping. Ebay has alot for around $70, and when i say best i mean performance gains.
I have a 02 Type S with a CAI (if that matters and P2R TB Spacer in the mail), Thanks in advance!
http://shop.ebay.com/i.html?_nkw=acu....c0.m270.l1313
lot of them scream headaches
if you can find a used comptech, i'd get that.. or if lucky.. XS-P (although those are a hit or miss.. i've had my luck with them..)
if not.. DC Sports.. last resort... megans or obx.
Check out www.ssautochrome.com for xs headers
Go with DC, unless your willing to wait/hunt around for CT/XS.
I went with the Megan Racing headers and have not experienced any of the problems that I had read in the past. I took extra precautions and used Permatex High Temp gasket compound and loose fit all my header pieces, gradually and random evenly tightened all the flanges. They matched up perfectly with my Tanabe SMH stainless steel exhaust that I had previously installed. I just went with a Random Technology high flow cat. To me, it is an awesome set up. The only thing I had to modify is the aft O2 sensor. I undone one clip and rerouted the sensor wire to reach the bung.
It has a deep low rumble/growl at idle and during WOT excelleration up to 5K rpm and then she opens up with a NASCAR sound. No popcorn popper sound there!
I don't think you would disappointed with the Megans and they would save you well needed bucks for other mods. They may sound different with other exhaust systems though, not sure.
Last edited by brune55; 04-05-2011 at 05:41 PM. Reason: Missed an important consideration.
DC if you want quality on a budget, Ive modded and install the ebay ones before(not on my car), with a little work (i.e. port match,check welds and tack weak spots) there worth it..
even worked my oem one on my last car, for 30$ it looked just like my DC did.
I have the OBX turbo header now and only had to do 3 tack welds and clean up 2 collectors.
