Governor???
Old May 15, 2007 | 07:23 PM
ridindirtyinva's Avatar
You got spanked by a 4-DR
Governor???
OK, call me stupid , but do the '03 TL-S's have a governor? I only had mine up to 120,(complete stock other than a K&N air filter, the filter not the intake) but at idle or in nuetral it redlines at 5000RPM. Is there a way to make it go beyond that?
Old May 15, 2007 | 07:30 PM
I hate cars's Avatar
Most cars have the revlimiter set lower in park and neutral vs in gear so people don't pin the throttle and hold it at redline forever. It's sort of an idiot proof mode.
Old May 15, 2007 | 11:18 PM
csmeance's Avatar
not to be rude, but it may be much more helpful to post in the 2nd Gen section as you have a 2003 Tl. BUt if you meant 2004, the governer limits the car at about 152 or 160 MPH. Also the car has many rev limiters set. In Park and netural it is set to 5000 RPM. In driving gears it is set to shift about 500 RPM befor redline on an Auto, but on a manual, there is a rev limiter at about 7K RPMs.
Old May 16, 2007 | 09:45 AM
Ron A's Avatar
Administrator
moved to 2G TL
Old May 16, 2007 | 12:23 PM
DOH!!!!! my bad......thanks.......
Old May 16, 2007 | 01:45 PM
adamlee05's Avatar
Thread Police Chief
Rev wise your car will rev to 6900 RPM since its a Type-S. The TL-P is 6700 unless in Sport mode, during which it also goes to 6900 RPM. Of course these numbers assume you are not in park. I'm not sure about rev limiting in park since I don't regularly rev my car in park. Speed wise, which is what the govenor does, both TL-P's and your Type-S are limited at 149MPH. I've taken my TL-P to 147mph but I was coming to a turn and didnt want to risk death just to go the additional 2mph. Also, where as your guage may say you are doing a set speed, you in actuallity probably aren't. The higher in speed you go, the more inaccurate your guage is. So you might go 146mph according to your guage and really be going or 149, or maybe it says 153mph but still its 149. Either way you cannot pass 149mph (under your cars own power that is) without modifying your ECU. Sure you could probably slingshot it past that by going down a steep mountain and blowing NOS at the last minute or something, but once you hit 149 your ECU will cut the fuel down enough to not allow your engine to power you any further.
Hope that helps
Old May 16, 2007 | 01:47 PM
EL19's Avatar
i thnk my 03 TLS tops out at about 153mph in 4th...but wen i shifted to 5th at 153mph i felt like i had more left...maybe i didnt cuz i didnt try i ran into traffic
Old May 16, 2007 | 01:49 PM
adamlee05's Avatar
Thread Police Chief
LOL i was editing my post when you posted L's. DOH! Funny how I just happened to pick 153 as a scenario number and its the same one you had
ALSO, rim and tire sizes affect the accuracy of your cars computer to determine your speed.
Old May 16, 2007 | 02:20 PM
fsttyms1's Avatar
It wont rev anyhigher in parkor neutral. There is nothing you can do to get rid of it
Old May 16, 2007 | 08:12 PM
Well, I still have factory 17's on.
Old May 17, 2007 | 12:37 AM
adamlee05's Avatar
Thread Police Chief
Like the man said, screwed.
