A/F ratio
Old Oct 2, 2006 | 04:38 PM
type-s09's Avatar
13.2@ 107 on Street tires
A/F ratio
Does anyone know what the recommended a/f ratio is on a 03 TL-S. Mine is at 12.5-12.6 WOT...just seeing if i need a tune..i am NA
Old Oct 4, 2006 | 08:49 AM
paul_huryk's Avatar
Pleasure Unit
Gasoline motors all make peak power at 12.9 to 13.1 air/fuel ratios - so you are a bit rich. However, most factory computers run it a bit rich so they won't have to deal with detonation and possible engine damage under warranty.
Old Oct 4, 2006 | 09:15 PM
Inaccurate's Avatar
How does a person know what their A/F ratio is ?
Old Oct 4, 2006 | 10:34 PM
fsttyms1's Avatar
most find out while on a dyno, or with a wide band o2 and software
Old Oct 4, 2006 | 11:06 PM
DMMTL A-SPEC's Avatar
I ran my evo WOT @11.4-11.6. Most important is that you have no knock.
AEM wideband is what I used. Of course I had AEM ems.
Most dyno's use the tail pipe which tends to read a bit leaner than in the DP.
Old Oct 5, 2006 | 10:42 AM
Excelerate's Avatar
Former Sponsor
A car with forced induction requires totally different A/F ratios than a naturally aspirated car. N/A at WOT should be about 13:1. F/I at WOT should at peak boost be about 12:1 and then at peak power dip down to 11.5:1
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
Sep 15, 2015 06:44 PM
Billu99tl
Sep 13, 2015 11:30 AM
