egr porting? and grounding motor?
Old Apr 17, 2011 | 12:19 AM
Jose2gtl's Avatar
what is egr porting? does grounding my engine better work? if so how do i do it myself?
please post any other low budget mods that will help performance, thanks
Old Apr 17, 2011 | 10:04 AM
01tl4tl's Avatar
egr port/passage CLEANING is a DIY we need to keep that system operating
Intake port opening to gasket size matching- can be done by a shop or at home if good with a dremel- that opens up and smooths airflow into the manifold
One company here offers new manifolds that are ported on their special machine for max precision and power
Grounding is to add more ground straps from points on the engine to a central point or just to a good ground on frame for each wire
See the diy master list https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
and the sponsored sales threads for other mod parts and descriptions
https://acurazine.com/forums/black-market-8/
you can always google basic parts questions like this too
Old Apr 17, 2011 | 10:15 AM
01tl4tl's Avatar
the extra ground straps improve signal stabilty from sensors to the ECU, so the car does run slightly better
you can DIY a set easily, doesnt need to be thick wire--see parts stores for metal strip ones from exhaust manifold bolt to ground point as examples
Old Apr 17, 2011 | 11:31 PM
Jose2gtl's Avatar
how do i know the point of reference on a motor where i ground wire at? cause i want to do this myself
Old Apr 18, 2011 | 12:33 AM
01tl4tl's Avatar
use the link I posted above to the diy list
read the one about grounding kits
look up ads on the internet for them, or our vendors ads in the sponsored sales link also provided above!
- see pics there of installation
You can use a small metal plate bolted to the frame rail and run all the wires to it.
Or you can run each wire to the frame by itself,,depends on how much room you have to work
a wire from alt, ps and engine should go to the extra ground--those help the most
Do not go in series with the grounds,,go from part to ground, not part to part to part-- to ground
one threads post has it all going together and finally to battery ground--NO!!
doesnt work right that way.need seperate ground system -from the battery
Old Apr 18, 2011 | 03:04 PM
Jose2gtl's Avatar
thanks alot that was helpful but what is the "ps" when you mentioned the alt, ps , engine>?
Old Apr 18, 2011 | 06:31 PM
01tl4tl's Avatar
PS= Power Steering pump
Alt =alternator--
batt= battery--
engine= exhaust bolt -to ground
Old Apr 18, 2011 | 09:26 PM
Jose2gtl's Avatar
thanks man
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
