DIY: Seafoam 2nd GEN TL (sorta) work in progress
Old 04-06-2009, 11:09 PM
  #561
niju321's Avatar
Originally Posted by Eddystone
I read that someone said 3" but I got a 3/8 tube. So after I wait 10-15 mins after VAC line, do I start the car and rev (what I see everyone do on Youtube) or start and drive off right away ? Do I drive hard like a crazy driver ? people said to keep at 4K rpm, I dont think my car can stay on 4K rpm ?
3/8 inch inner diameter should be ok. i think that's what i have as well, even though the real size you need is 5/16" IIRC. 3/8 worked fine for me tho, just a little noisier.
after you do the waiting, you start up the car...it'll run poorly for a moment and there will be a lot of smoke. after about 5-10 seconds go drive hard. keep it in one gear (by using the sequential sportshift/tiptronic/manual shifting) and yes, keep the revs high. i held it between 4k-5k rpm for 15 mins with no problems....just don't redline it and you'll be fine.
Old 04-06-2009, 11:36 PM
  #562
Eddystone's Avatar
What gear were you in when you did the 4k-5k for 15 mins ?
I've never used the tiptronic before because I dont know how, how do I ?
Old 04-07-2009, 12:10 AM
  #563
niju321's Avatar
it doesn't matter all that much what gear you're in as long as you don't exceed the speed limit. i was in a neighborhood so i kept it in 1st.
how to use tiptronic...when in D4 (or D5, depending on what year your car is) move the shifter to the left, then a number will appear in your tachometer, that's the gear you're in, there's a + and - in the shift gate, push the shifter toward the + to upshift and - to downshift...
Old 04-07-2009, 12:19 AM
  #564
Eddystone's Avatar
Thanks for all the tip, if tomorrow is a nice day then I will be doing the VAC line.
So its 1/2 can of a 16oz can in the VAC line right ?
Old 04-07-2009, 10:01 AM
  #565
niju321's Avatar
see page 14
Old 04-07-2009, 07:44 PM
  #566
Eddystone's Avatar
I just did a 1/2 can into the VAC line and it took about 15-20 mins, I then waited 12 mins to start the car and it started up fine. I went for a drive on 2nd gear at 4K rpm for a bit then slow down and did it again for 15-20 mins. I didnt see much smoke, did I do something wrong ?
Old 04-07-2009, 11:44 PM
  #567
mlrskn06's Avatar
http://www.youtube.com/watch?v=UZehlus-aLg
Old 04-07-2009, 11:48 PM
  #568
Eddystone's Avatar
Is it fine to just rev instead of doing the drive ?
  #569
mlrskn06's Avatar
^ thats me only using like a 3rd of 1 can of seafoam and that was plenty of smoke did urs come out something like that?
Old 04-08-2009, 12:05 AM
  #570
Eddystone's Avatar
Some smoke came out but not as much as that and not long, maybe because it was windy when I did mines. I did half a can, going to do the other half in acouple of days when its better weather because of this poor result (IMO).
Old 04-08-2009, 05:43 PM
  #571
niju321's Avatar
want to make sure ur car was fully warmed up before putting the seafoam in the vac line...i used a full can on my car, but 1/2 can in and some smoke was coming...
Old 04-08-2009, 11:38 PM
  #572
Eddystone's Avatar
Ya it was fully warmed and smoked alittle bit half way through, will do the other half Friday and see what happens.
Old 04-10-2009, 04:49 AM
  #573
Eddystone's Avatar
Is it ok to just rev at 4k rpm? Instead of the drive
Old 04-10-2009, 08:31 AM
  #574
AZ Community Team
Bearcat94's Avatar
Received 7,771 Likes on 4,342 Posts
You're going to rev your car to 4k for 15 - 20 minutes?!?!?
Just drive it. The instructions are tried and true; no need to go mucking around with something simple.
Old 04-10-2009, 03:59 PM
  #575
niju321's Avatar
methinks the load on the engine will help it heat up more and burn off more deposits than just revving it, plus better for cooling than 0mph
Old 04-12-2009, 12:21 PM
  #576
Eddystone's Avatar
I did a half can into the VAC line last week, is it ok to do the other half can through the VAC line again today ?
Old 04-12-2009, 02:02 PM
  #577
niju321's Avatar
Yes.
Old 04-13-2009, 04:02 PM
  #578
Go Brewers!
jstahnke10's Avatar
Did mine this weekend. Plenty of smoke and funny looks from people... Thanks ok...
Used the full can and let it sit.
Rough start, but it turned and away I went...
Seems much smoother now!
Old 04-13-2009, 07:14 PM
  #579
Eddystone's Avatar
I just did the other half can in the VAC line and got *some* smoke half way through, waited 15 mins then started and revved to 4k rpm and had little smoke then thats it. Went for a drive at 4k down the highway and no smoke. Can it be because I only used half can ?
Old 04-13-2009, 09:39 PM
  #580
niju321's Avatar
paging 01tl4tl...
Old 04-14-2009, 09:13 AM
  #581
6MT Someday..
twistedwedge's Avatar
maybe your engine isnt all that dirty..? I only put half a can in mine, and when I took off down the road it looked like spyhunter smoke screen behind me..
Old 05-07-2009, 12:48 PM
  #582
Eddystone's Avatar
Should I disconnect the VAC hose before or after the engine is on and then start sucking ?
Old 05-07-2009, 01:30 PM
  #583
6MT Someday..
^^^It doesnt matter man..either will work.
Old 05-08-2009, 11:58 PM
  #584
speedemon90's Avatar
When you do the fuel tank you dont have to do the vac line right?? Also if you put a whole can in a 1/4 tank of gas doesnt the car eventually run out of gas, then will it run on seafoam?? And should i replace the spark plugs after the fuel tank run or the vac run if i do it at different times?? Lol sorry for all the questions
Old 05-09-2009, 01:26 AM
  #585
nayaab88's Avatar
Do both fuel tank and vac line.
The seafoam mixes with the gas in your tank, I don't even know what to say to this one.
Replace spark plugs after/if you put seafoam in the oil.
Did you even read the DIY?
Old 05-09-2009, 02:19 AM
  #586
Haha yea but a while ago.
wait so if i do fuel and vac only, no need to change out the spark plugs?
Old 05-09-2009, 01:22 PM
  #587
niju321's Avatar
you don't need to change the spark plugs if you put foam in the oil, but you do need to change oil and filter.
no need for spark plug change unless:
you're due for them anyway
you don't do the burnoff drive properly, leaving crud on the plugs
Old 05-10-2009, 11:24 AM
  #588
ecaf005's Avatar
Just seafoamed the tL this morning using post#149 by 01tl4tl ( thanks! ). Changed the oil and installed new spark plugs too, everything seems to be running great now.
Old 05-10-2009, 01:55 PM
  #589
nayaab88's Avatar
oh ya, crap, what was i thinking you dont need to change the plugs, just the oil.
Old 05-22-2009, 12:02 PM
  #590
Eddystone's Avatar
Why does the car choke when I disconnect the hose while the car is on ? feels like someone is revving then stopping then revving again constantly.
Old 05-22-2009, 12:46 PM
  #591
niju321's Avatar
it's normal because the hose you are disconnecting carries so much vacuum. disrupting that (as you do by disconnecting the hose) causes the "choking" you experienced.
Old 05-31-2009, 06:14 PM
  #592
so i read ur suppose to do another seafoam run after like 2000 miles, should i switch out my spark plugs after the first run or the second one 2000 miles later. I'm due for a spark plug change, or does it not really matter at all when i change it
Old 05-31-2009, 07:18 PM
  #593
It's the Halladay season!
hANDYcaptd's Avatar
^ If you're due anyway, I'd do it after second one.
...Welcome back BTW...
Old 05-31-2009, 07:52 PM
  #594
kk sounds good i think ill do that as soon as my school ends. Hahaha thanks. It was hard to find things to do on the comp over that week!
Old 06-06-2009, 08:01 PM
  #595
Rhino31's Avatar
quick question, do you have to do the oil treatment the sametime you do the rest, or can the oil treatment wait until before you head in for your next change?
Old 06-06-2009, 08:29 PM
  #596
wham bam thank you ma'am
Rajca's Avatar
it can wait
Old 06-08-2009, 09:04 PM
  #597
Eddystone's Avatar
Is this the correct and up to date method for crankcase?
"Use a whole can in the crankcase (pour into oil fill). Get an oil change after a MINIMUM of 30 miles/50 kms and MAXIMUM of 100 miles/160 kms."
Old 06-10-2009, 05:52 AM
  #598
Is it required that we get a new hose, i know some people said they used funnels, is that alright. Or should i jjust spend the extra bucks and get a hose to use for the seafoam.
Old 06-10-2009, 05:58 AM
  #599
or can i just put the seafoam contents in a water bottle and stick the original hose in so i can see it. I remember reading that if the hose gets wet there is a chance that it might swell up and can possibly cause a vacuum leak. Is that true?
Old 06-10-2009, 08:28 AM
  #600
hANDYcaptd's Avatar
^Yup, just get the clear hose.
Quick Reply: DIY: Seafoam 2nd GEN TL (sorta) work in progress
