DIY: Seafoam 2nd GEN TL (sorta) work in progress
#521
the vac line is extremely easy! i hadn't even done an oil change by myself in my life (until i put seafoam in the oil) and i still got the can in with no problems.
#523
What if I just use one can in the tank and one in the oil ? because I am not a mechanic and dont think I can do the vac line myself.
So after I pour it in the oil, how long after do I need to do an oil change ?
What if I just pour a can in the tank ? will it still be a good cleaner ? a whole can to what amount of gas ?
I put a can in the oil, drove around for about 15 minutes and changed the oil. It was black, but looked like standard used dino oil so I'm not sure if that was long enough.
As for the gas, 2oz per gallon in the tank is the cleaning dosage that seems to have been agreed upon.
Happy foaming--just helped foam an es300 with 175k miles (it looked like a forest fire) and foaming an SL with 125k helped it crack 90 for the first time (saturn, not benz)
#524
AZ Community Team
Received 7,771 Likes
![](http://img156.imageshack.us/img156/6625/vtecyo.jpg)
![Rock Star](https://acurazine.com/forums/images/smilies/rockstar.gif)
In ImageShack, where the links are, use the "Code" tab and the "Direct" link. Then put "[IMG]" before the link and "[/IMG]" after the link.
Quote this post to see a what I mean.
#526
I found the vac line to be most beneficial in terms of power output.
#527
Ok so just to clarify: 2000 TL
1. Pour a whole can into half full gas tank ?
2. Pour a whole can into oil tank ?
3. Let it suck a whole can into the VAC line ? (as seen in this post)
4. Drive around for 15 mins or so until the smoke is gone ?
5. Do oil change ?
6. Enjoy the new performance ? / done ?
Should I do everything while the car is running ? I know the car has to be on for the VAC line and driving step.
All should take a few hours right ?
5. Do oil change ?
#529
wrong order. you don't want to do the smoking drive while it's in the oil. do the oil tank and change either before or after the other things. and don't put it in the oil while the engine is running.
#530
1. One can in the oil tank, then drive around for 15 mins or so then do oil change ?
2. One can in the gas tank.
3. One can in the VAC line ?
Steps 2 and 3 at the same time while car is off ?
#531
with car off, put 1 can in oil, drive around for 15 min (normally), change oil.
one can in gas tank
turn car on
one can in vac line
turn car off and wait 10-15 min
drive around for 10-15 min (HARD driving, keep the revs at 4000-5500 rpm as much as possible, try the sport shift and hold it in a gear so you don't have to speed)
one can in gas tank
turn car on
one can in vac line
#532
#535
ok well apparently when i did this a couple weeks ago i didn't read the instructions and i left the seafoam in the oil... and its STILL in the oil... lol is that bad? is it gonna hurt anything?
#536
the concern with leaving it in the oil too long is that all the gunk will clog up your filter. if you didn't have too many miles on this filter then you should be fine...
#539
I am thinking about pouring one can (435 ML) into gas tank for now ? and then VAC line and oil tank in a few weeks when its about time to do an oil change ? how many liters of gas is in a 2000 TL ? someone said pour a whole can (435 ML) into half tank of gas ?
#540
I like to add the full can to 1/4 to 1/2 a tank tops.
#542
#548
#550
If I dont pour it in the oil tank then I dont have to do an oil change ? it will smoke if I put it in the VAC line ?
I just poured a whole can into the gas tank today with half tank of gas. Dont really notice anything. Should I wait until the gas goes empty then fill up gas ?
#552
6MT Someday..
did the vac line treatment to my wifes odyssey the other day, its got 189,000 Miles-and boy did it make the difference! It was amazing the amount of smoke that came out when I took it out for a drive..lol.
also hit the TL up yesterday (vac line) didnt smoke near as much, probably has a lot to do with the car having 60,000 less miles than the van. Seems like it smoothed out the idle quite a bit. Waiting for my gas to drop so I can do the tank treatment on both vehicles.
Good stuff!
Good stuff!
#555
#557
I read that someone said 3" but I got a 3/8 tube. So after I wait 10-15 mins after VAC line, do I start the car and rev (what I see everyone do on Youtube) or start and drive off right away ? Do I drive hard like a crazy driver ? people said to keep at 4K rpm, I dont think my car can stay on 4K rpm ?
