DC Header resonance is killing me!
I'm getting pretty significant resonance with a cold motor at idle in gear and also in the 1500-2220 rpm range when warm. Cruising down the highway is no problem but around town it's just enough to drive me nuts.
I've tried everything from retorquing the system to disassembling and reassembling and tightening in different sequences. For now I've gone back to a stock setup, but after having a taste of the performance bump in the Vtec rpm range with the DC's, I'd really like to find a solution to this problem if there is one.
I'm thinking I might give DC Sports a call to see what they have to say.
Any suggestions?
Any suggestions?
when you are changing out exhaust pieces, you are experimenting with sound. the only way to find a sound to your liking is to keep playing around with exhaust pieces......
maybe you'll want to add a long resonator, to help quell the resonance...
maybe by adding a resonator; it'll quiet down the whole exhaust to where you want more noise..maybe not. keep playing by adding or deleting exhaust pieces.
Stock system so I don't have the option of changing things up.
When I say resonance, I'm talking about a loud vibration that rumbles into the cabin. Almost like a REALLY bad heat shield that is loose, but It is definitely not any of the shields.
With the car up on a lift and the engine running, I can feel a vibration throughout the downpipe which seems to be the culprit. I'm wondering if different gaskets might isolate the headers from the downpipe enough to stop the vibration.
Any suggestions?
Any suggestions?
I have DC headers too so any info on this would help a ton.
Any recommendations on alternative gaskets?
I used this kit, IIRC'ly, back when I had an exhaust leak at the cat. The one I used did not fit 'exactly' so I had to modify it. It stopped the leak though.
YMMV.
https://www.rv6-p.com/gasket-set.html
YMMV.https://www.rv6-p.com/gasket-set.html
Ya if gaskets don't solve anything I'd place a resonator right after the cat. If you look at the 2nd gen TL, they have a small resonator there where the CL only has the one before the Y split.
So add a resonator after the cat AND keep the existing stock resonator or delete the stocker and just replace it with a larger aftermarket?
I'm still trying to wrap my head around how a resonator downstream will stop vibrations in the J pipe.
Or just replace some of the gaskets with OEM ones I used Fel-pro gaskets for the DC headers and the gaskets included in the Magnaflow Cat for the Converter.
I think if it's vibrations, then something is off on the setup. If it's resonance (like a dull hum at certain RMPs) then you need to just put an addition resonator after the cat, keep your OEM one near the Y split.
Just to recap. A curious question. When you dropped in the J35A3, I presume you installed the header manifolds on the engine first, torqued them down, and then installed the engine. At some point when you were ready, after the engine install, you then placed new 'doughnut' gaskets on the J-pipe and mated it up to the two header manifolds loosely with the bolts/nuts. Then, after placing some kind of gasket material to the junction of the J-pipe/cat, this was then loosely attached with bolts/nuts to hold it all in place. When it came time to finally tightened everything down, what sequence did you use?
Did you first tighten the header manifold ends to the J-pipe and then proceed, finally, to the J-pipe/cat connection or start at the cat first then move to the manifold connections?
I'm experiencing the same thing with my setup and it's definitely a dull hum that is much more pronounced for the first couple of minutes until the exhaust warms up. When I installed the headers, I also swapped out my CA emissions OEM cat first for the XLR8 high flow cat and eventually for a Magnaflow Federal emissions one, so I never ran the combo of DC headers with the OEM CA emissions cat. What I can tell you is that besides there being more of an exhaust smell with the XLR8 cat, there was also a bit more of the resonance, so I decided to leave the Magnaflow cat on for now and sacrifice a few HP for cleaner exhaust and a bit less resonance.
By design, cast iron exhaust manifolds are supposed to quiet down the exhaust, It makes sense that by replacing them with thinner walled stainless steel headers and possibly also a slightly thinner walled J-pipe when compared to stock, you're going to get slightly increased exhaust noise.
FWIW, the DC Sports installation instructions call for the rear header to be fully tightened to the head first, the front header to be loosely installed, then the J-pipe fully tightened to the rear header flange, followed by the front header flange, and finally, the front header gets fully tightened at the head. This is the sequence that I followed and I have no leaks to speak of.
I agree with MBP 03, the cast iron OEM manifolds absorb a tremendous amount of vibration energy just by their sheer mass and density compared to the aftermarket headers.
The first time was exactly like MBP 03 said, per the install instructions. Tight rear manifold with loose front, then tighten rear downpipe, tighten front downpipe, tighten front manifold, then tighten cat. I've tried different variations with the same result. Either way I've never had any leakage issues, just this damn annoying vibration, hum, resonance or whatever you want to call it.
The only thing left is the flex pipe enclosed within the flex mesh? Otherwise, it sounds like the '...annoying vibration, hum, resonance...' is inherent to the engineering/materials the headers are made from. And then, of course, there is the 'experimentation' aspect of various resonators, as mentioned above, as a plan B.
Well, there is one other option, in the form of a set of overpriced 'Auto' CT-E headers in the Blackmarket for $900.
Got it. Well, it sure sounds like you've tried pretty much everything.
Loose Exhaust hanger bolt by the header down pipe
Any suggestions?
Any suggestions?
i have a feeling that this is causing the noise because our TL’s create a good amount of resonance at the 1800 rpm mark the thin DC sports down pipe vibrated more than the thicker stock one and that vibration was causing a noise at the loose hanger bolt.
i didn’t want to risk breaking the bolt so what I did was I made rubber spacers from old bushings to fill the gap so there wouldn’t be any play anymore and bam the noise was gone!
Check to see if that hanger bolt is loose on your TL too!
MadisonTLS
Jul 31, 2003 09:32 PM
