CL-S 6-speed Transmission Swap List
USDM UA5 A-Spec
Planning and saving up for it, but wanted to verify from those who have done it... I have found the overall worst-case cost of everything from acuraoemparts.com but wanted to know if all the parts are correct. I plan to try and go the used parts was as well since $4500 for all new parts might be alittle steep. This was all based off of reading fsttyms1's guided 6 speed conversion thread. Some parts I had to guess since no part numbers included.
Let me know if certain parts can be skipped or if I need to modify some stuff since I already have a TL-S engine and currently have the following engine mods(hoping to cut as much cost as possible):
1. Comptech CL-S 6spd Headers
2. UR Crank Pulley
3. Comptech TL-S Icebox
Also, any suggestions from past experiences would be appreciated.
Product SKU# Description Remove Quantity Unit Price Discount Total Price
11860-PGE-A10 PLATE ASSY., FR. TIMING BELT BACK COVER $19.62
13621-PGE-A11 PULLEY, TIMING BELT DRIVE $58.86
14260-PGE-A11 PULLEY, FR. TIMING BELT DRIVEN $78.74
22100-PGE-026 FLYWHEEL $402.18
31200-PGE-A11 MOTOR ASSY., STARTER(SM-44237) (MITSUBA) $398.10
32100-S3M-A12 WIRE HARN, R. CABIN $220.38
32110-PGE-A11 WIRE HARNESS, ENGINE $256.82
32117-S3M-A31 WIRE HARNESS, INSTRUMENT $208.30
32120-S3M-A20 WIRE HARNESS, L. CABIN $131.08
32150-S3M-A32 WIRE HARNESS, DASHBOARD $138.30
37500-PGE-A11 SENSOR ASSY., CRANK $435.46 $435.46
37501-PGE-A10 SUB-HARNESS, CRANK SENSOR $16.46
37840-PGE-A11 SENSOR ASSY., TDC $59.70
37841-PGE-A10 SUB-HARNESS, TDC (1-2) $8.74
39531-S3M-A11 ECU UNIT, ON-STAR $612.20
46600-S3M-A51 PEDAL ASSY., BRAKE $55.88
46910-S3M-A01 PEDAL, CLUTCH $51.02
46922-S3M-A01 MASTER CYLINDER ASSY., CLUTCH $57.32
46960-S3M-A01 PIPE A, CLUTCH $4.70
46961-S3M-A02 HOSE, CLUTCH $22.34
46965-S5A-013 TANK ASSY., CLUTCH FLUID $15.94
46970-S3M-A01 PIPE B, CLUTCH $6.98
46990-S84-A01 BRACKET, CLUTCH PEDAL $27.26
47105-S3M-A04 ZA LEVER ASSY., PARKING BRAKE $51.58
50805-S3M-A03 RUBBER, FR. TRANSMISSION MOUNTING $29.20
50806-S3M-A03 RUBBER, RR. TRANSMISSION MOUNTING $41.30
50810-S3M-A01 RUBBER ASSY., RR. ENGINE MOUNTING (ECM) $124.96
50826-S3M-A00 BRACKET, FR. ENGINE MOUNTING $58.86
50827-S3M-A00 BRACKET, RR. ENGINE MOUNTING $87.72
54100-S3M-A01 LEVER SUB-ASSY., CHANGE $64.34
54102-SL0-023ZB KNOB, CHANGE LEVER (DIMPLE/LEATHER) $175.78
54310-S3M-A01 WIRE, CHANGE $119.36
77230-S3M-A01ZA HOLDER ASSY., CUP $89.18
83414-S3M-A01ZA BOOT ASSY., CHANGE LEVER $91.54
90011-PGE-000 BOLT (12MM) $18.08 (*** 8 PIECES ***)
90166-S3M-A00 BOLT, FLANGE (12X25) $1.90
Shipping Information
Shipping Method: Ground
Comments / Special Instructions:
Subtotal: $4,240.18
*Shipping Charge [Shipping
Charge may vary with package
size / weight]:
$254.41
Handling Charge: $3.95
**Sales Tax: $0.00
Total Order : $4,498.54
2. UR Crank Pulley
Subtotal: $4,240.18
size / weight]:
$254.41
**Sales Tax: $0.00
First start out finding every thing you can used. Then after you have exhausted your search get the parts new that you need. You will want a flywheel and clutch that are new. Dont get these used.
OM NOM NOM NOM
1 Post
oh! check out www . car-part . com. you can find a few of the things you need on there for a decent price. I found out the starter on the front clip of my CL-S i bought for the swap was defected, so ordered a used one from car-part for only 85 bucks shipped.
justin7779
12-25-2015 10:33 PM
39531s3ma11, 46960s3ma01, 6sp, 83414s3ma01za, acurazine, cl, cls, clutch, installation, number, phone, speed, swap, tl, transmission
