CL-S 6-speed Transmission Swap List
Old 04-28-2008, 01:12 PM
USDM UA5 A-Spec
BiggyMcWang's Avatar
Planning and saving up for it, but wanted to verify from those who have done it... I have found the overall worst-case cost of everything from acuraoemparts.com but wanted to know if all the parts are correct. I plan to try and go the used parts was as well since $4500 for all new parts might be alittle steep. This was all based off of reading fsttyms1's guided 6 speed conversion thread. Some parts I had to guess since no part numbers included.
Let me know if certain parts can be skipped or if I need to modify some stuff since I already have a TL-S engine and currently have the following engine mods(hoping to cut as much cost as possible):
1. Comptech CL-S 6spd Headers
2. UR Crank Pulley
3. Comptech TL-S Icebox
Also, any suggestions from past experiences would be appreciated.
Product SKU# Description Remove Quantity Unit Price Discount Total Price
11860-PGE-A10 PLATE ASSY., FR. TIMING BELT BACK COVER $19.62
13621-PGE-A11 PULLEY, TIMING BELT DRIVE $58.86
14260-PGE-A11 PULLEY, FR. TIMING BELT DRIVEN $78.74
22100-PGE-026 FLYWHEEL $402.18
31200-PGE-A11 MOTOR ASSY., STARTER(SM-44237) (MITSUBA) $398.10
32100-S3M-A12 WIRE HARN, R. CABIN $220.38
32110-PGE-A11 WIRE HARNESS, ENGINE $256.82
32117-S3M-A31 WIRE HARNESS, INSTRUMENT $208.30
32120-S3M-A20 WIRE HARNESS, L. CABIN $131.08
32150-S3M-A32 WIRE HARNESS, DASHBOARD $138.30
37500-PGE-A11 SENSOR ASSY., CRANK $435.46 $435.46
37501-PGE-A10 SUB-HARNESS, CRANK SENSOR $16.46
37840-PGE-A11 SENSOR ASSY., TDC $59.70
37841-PGE-A10 SUB-HARNESS, TDC (1-2) $8.74
39531-S3M-A11 ECU UNIT, ON-STAR $612.20
46600-S3M-A51 PEDAL ASSY., BRAKE $55.88
46910-S3M-A01 PEDAL, CLUTCH $51.02
46922-S3M-A01 MASTER CYLINDER ASSY., CLUTCH $57.32
46960-S3M-A01 PIPE A, CLUTCH $4.70
46961-S3M-A02 HOSE, CLUTCH $22.34
46965-S5A-013 TANK ASSY., CLUTCH FLUID $15.94
46970-S3M-A01 PIPE B, CLUTCH $6.98
46990-S84-A01 BRACKET, CLUTCH PEDAL $27.26
47105-S3M-A04 ZA LEVER ASSY., PARKING BRAKE $51.58
50805-S3M-A03 RUBBER, FR. TRANSMISSION MOUNTING $29.20
50806-S3M-A03 RUBBER, RR. TRANSMISSION MOUNTING $41.30
50810-S3M-A01 RUBBER ASSY., RR. ENGINE MOUNTING (ECM) $124.96
50826-S3M-A00 BRACKET, FR. ENGINE MOUNTING $58.86
50827-S3M-A00 BRACKET, RR. ENGINE MOUNTING $87.72
54100-S3M-A01 LEVER SUB-ASSY., CHANGE $64.34
54102-SL0-023ZB KNOB, CHANGE LEVER (DIMPLE/LEATHER) $175.78
54310-S3M-A01 WIRE, CHANGE $119.36
77230-S3M-A01ZA HOLDER ASSY., CUP $89.18
83414-S3M-A01ZA BOOT ASSY., CHANGE LEVER $91.54
90011-PGE-000 BOLT (12MM) $18.08 (*** 8 PIECES ***)
90166-S3M-A00 BOLT, FLANGE (12X25) $1.90
Shipping Information
Shipping Method: Ground
Comments / Special Instructions:
Subtotal: $4,240.18
*Shipping Charge [Shipping
Charge may vary with package
size / weight]:
$254.41
Handling Charge: $3.95
**Sales Tax: $0.00
Total Order : $4,498.54
Old 04-28-2008, 02:08 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
First start out finding every thing you can used. Then after you have exhausted your search get the parts new that you need. You will want a flywheel and clutch that are new. Dont get these used.
Old 04-28-2008, 05:42 PM
OM NOM NOM NOM
heyitsvu's Avatar
oh! check out www . car-part . com. you can find a few of the things you need on there for a decent price. I found out the starter on the front clip of my CL-S i bought for the swap was defected, so ordered a used one from car-part for only 85 bucks shipped.
Old 04-28-2008, 06:55 PM
USDM UA5 A-Spec
thanks guys... I'll look into that stuff as well.
Old 07-10-2017, 11:26 PM
5th Gear
jody.orlandoCL's Avatar
I am in need of the Boot Assembly Change Lever. Where are you finding it at that Price?
drone619
01-26-2016 07:09 PM
justin7779
12-25-2015 10:33 PM
ghuns
09-16-2015 04:26 PM
Allen_442
09-08-2015 06:01 PM
Quick Reply: CL-S 6-speed Transmission Swap List
