Cabin Air Filter replacement
Replacement Instructions
Great directions for replacing the air filter below from previous thread. Best to do it every 15-20 K. Mine was 84K, very filthy!!!
BTW in my 2002 TL-S,
serrated panel already cut.
Thanks!,
Jayman
Instructions (lifted from this site a while back) - sorry, no pics:
To access the interior air filters you will need a Philips screwdriver a pocket flat blade screw driver and a sharp knife. Open the glove box and empty it of whatever you have been hiding in there.
There is a air piston on the right side that slows the opening speed it is attached to the door with a screw, remove the screw, pop of the air piston.
There are two stops on the inside the glove box, pop both out with the small flat blade.
The glove box will now open downwards, there are two Philips screws holding the door to the dashboard structure, remove both screws the door can now be removed.
You will now see two Philips screws that appear to hold nothing in place, remove these leave the metal clips in place.
There is a serrated panel visible it must be cut away from the dashboard structure, save this panel as it is to be reused later.
There is now a vertical white plastic panel visible that can be snapped out of the way and removed.
The filters are the two vertical boxes now visible, remove the bottom one first by pulling it towards you then lower the upper one and remove it as well.
Exchange the filters noting that they have arrows on them for airflow; the boxes that contain the filters are marked as well. Install the filters in the boxes and reassemble the filters in to the air box. Take the white panel and snap it back in place.
Now take the previously cut out plastic panel and turn it so the two hooks engage the two slots in the dash structure, the two screws that did not do anything are now used to secure this panel in place.
Reassemble the glove box in reverse fashion from disassembly.
This job should take you about twenty minutes or less.
Thanks!,
Jayman
Thanks!,
Jayman
The filters are the two vertical boxes now visible, remove the bottom one first by pulling it towards you then lower the upper one and remove it as well.Exchange the filters noting that they have arrows on them for airflow; the boxes that contain the filters are marked as well. Install the filters in the boxes and reassemble the filters in to the air box. Take the white panel and snap it back in place.
Thanks!,
Jayman
Am I missing something here. If 2 items are vertical can One really be on the bottom?
Originally Posted by medrxman
Hi,
https://acurazine.com/forums/showthread.php?t=107821
Originally Posted by fsttyms1
check out the link (also in the 2nd post). It shows pictures along with instructions
My error..THANKS
Abe_Froman
09-16-2015 01:27 PM
