Better Handling
I will have to disagree with you on this point because stiffer spring rates will in fact stiffen the ride over bumps and choppy roads. On a smooth road, i will agree with you in that springs will not affect the ride at all.
It just so happens that many of the spring manufacturers choose to use progressive rate springs(good ride and only stiff when we need it around a corner or hard braking) which substantially help with ride quality while having a much higher spring rate closer to the end of the compression of the spring .
Not necessarily. I have run coilovers in the past and i much prefer shock and springs. The other thing in snow belt areas coilovers dont tend to last. The adjustability goes out the window pretty quick once the sand and salt get to them (been there fought with that).
If you're saying that coilovers don't last because the adjustability goes out the window, I'll give that aspect to you. You won't be able to adjust them after some time passes, but the actual "suspension" function of the coils will last just about forever. However, this won't be as big of a factor if you live in relatively arid climate areas such as myself in SoCal.
Also, how many people actually tinker with their coils that much? I for one took the time to get my setup the way I wanted it when I first installed my set, and have never messed with them since. I think the majority of people are in the same boat, although I could be wrong?
Unless you get custom valved shocks specifically made to be mated to your springs, coils > springs/shocks.
I see. Well, unless you get custom valved shocks, you won't have the optimum setup that coils provide, since the springs/shocks of the coils were specifically made for each other.
Now i do wish that H&R made a complete coilover kit for the TL like they do for some of the other cars.
If springs can provide a drop, eliminate front/rear pitching on quick starts/hard stops, and with the aid of sway bars, reduce roll in cornering, why even bother with anything other than stock struts/shocks? For daily drivers, it would seem springs and sway bars would be enough to satisfy most needs.
The konis are valved almost perfect for the H&R. Bilstien can be refalved as well pretty easy for them. Ive run plenty of coilovers and i much prefer setups like i have. I have found much better ride and performance out of them as opposed to coilovers. Most out there are more for ride height than performance. That has just been my experience with my various rides.
im told that if i take the springs it will become harder but if i leave the same dampers my car will not lower ? is that true or is that horse SH*T please let me know
I think a lot of folks (I used to) assume when someone says 'lower their car', they think of extreme lowering, where the top of the tire is covered by the wheel well. They don't realize that a 1.5 - 2.0" drop is really nothing. Here are some pics of before and after a 1.75" drop.
BEFORE
AFTER
As you can see, this is not drastic at all. You might not even notice how much room there is above the wheel in a stock setup until you see something like this.
BEFORE
AFTER
BEFORE
AFTER
BEFORE
AFTER
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
