6 Speed swap? help?
Old Nov 22, 2012 | 02:07 AM
AcraAdi93's Avatar
6 Speed swap? help?
Well im currently saving up for the 6 speed swap and what is more worth it? Buy a CL type S crashed off an auction and swap engines and trans with ecu and etc? Or buy the trans itself with ecu and sensors and etc? I have an 03 TL type S so I don't think I wont need the engine out of CL type S will I?
Old Nov 22, 2012 | 08:18 AM
fsttyms1's Avatar
Nope, you wont need the engine. Just need the front cam gear, cam sensors and crank gear and sensors. (and of course the manual engine harness)
Personally i would buy the trans and stuff to go along with it and buy a full standalone like the AEM EMS 30-6051 and find a tuner to tune it. You will get far better numbers out of the engine and have the ability to tune for future mods. Also it wont require you to change any wiring in the car. The cost of the AEM is about what you would spend on everything else.
Old Nov 22, 2012 | 11:42 AM
AcraAdi93's Avatar
So pretty much the whole swap will come out cheaper in this way as you're saying? And will the car think its a tl type s or cl type s then with the aem ecu? And is there a list of what I need somewhere for the swap?
Old Nov 22, 2012 | 01:47 PM
fsttyms1's Avatar
It will come about the same. If it had been available when I did mine I would have in a heart beat. I fully plan on switching to it when I put my new motor in.
What do you mean will the car think its a tl-s or cl-s?
Yea there is a list BUT its not for if you use the aem, no one has done a day with it. For the most part You will need everything associated with the trans. Look in the diy thread or use the search button to see all the 6 speed threads.
Old Nov 22, 2012 | 03:42 PM
AcraAdi93's Avatar
Since the aem covers 3/4 of the swap how much will it all cost in your opinion? And I read about the ems having to use the civic cluster ? What is up with that?
Old Nov 25, 2012 | 12:16 AM
Karanx7's Avatar
Unregistered Member
You think you could help me with the EMS install? I'm fully ready to do it, but I would just love if you had already done it, so you could give all the tips.
I'm pretty much true manual atm, but can switch back to auto wiring easily. A quick write up would help me out alot. Or just let me buy you an EMS and you write a complete DIY.
Old Nov 25, 2012 | 02:54 PM
fsttyms1's Avatar
I dont have mine wired up or installed. I wont be doing any of that until i get the new motor in and have time to bring it to a dyno to have them tune it so until then i wont be able to help.
Old Nov 25, 2012 | 02:56 PM
fsttyms1's Avatar
? all depends on what you can get the parts for. Should be no reason you cant wire it up to work with the TL cluster. Most of the guys running it are running it in civics with the J32 and with the civic wiring.
Old Nov 28, 2012 | 02:01 AM
AcraAdi93's Avatar
CL-S cluster will be good. I think the parts out of the CL type S sound better to me with ECU. I don't have anyone that can tune an EMS for me and install it. And how long did it take you to do the 6mt swap?
Old Nov 28, 2012 | 09:40 AM
fsttyms1's Avatar
If I had had all the parts before I installed it I could have done it in a day. Be prepared for lots of wiring going that route. You will have to do a bunch of repining of harnesses. Not trying to scare you from doing it. 85% or so is plug and play, 15% isnt and has to be repinned and figured out.
Old Nov 28, 2012 | 03:02 PM
AcraAdi93's Avatar
I got Rob to help and he says that it can be done easily no worries. Where did you get most of the parts from? And how much was the ECU and the tranny?
Old Nov 28, 2012 | 03:22 PM
fsttyms1's Avatar
start searching the internet for parts. Thats how i found mine. The 2 links below are where i got most of my parts.
http://car-part.com/
http://www.acuraautomotiveparts.org/...catdisplay.jsp
Old Dec 1, 2012 | 12:35 AM
westhaventl's Avatar
Moe T
I got a lot of my stuff from car-part.com as well. If you look on fsttyms1's list a lot of the big ticket items(except clutch and actual trans) are really cheap brand new oem. I used acuraoemparts.com for my oem stuff. Just saving up for this AEM EMS now. In the next few months i should be done...hopefully
Old Dec 6, 2012 | 11:47 AM
assclown's Avatar
2000 acura tl FPR
It's plug and play. Just hook all your auto sensors and harness back up, then plug the AEM in as you would the stock ECU
Put the key in the ignition DO NOT START IT! Hook up the USB to your computer, open AEM Tuner. Load the V6 Honda Acura calibration when it opens, click on ECU> Upload calibration and select the one you have and upload it. From there I believe it's ready to start. Should crank right over, then drive to a tuner for the rest
Old Dec 12, 2012 | 03:10 AM
AcraAdi93's Avatar
I might just go the whole route by doing the CL ecu and what not
Old Dec 12, 2012 | 03:48 AM
AcraAdi93's Avatar
Where can I find a trans? I seem to have found some no accurate description of the conditions and what not. Any places I can look for one?
Old Dec 12, 2012 | 01:19 PM
fsttyms1's Avatar
See post 12
Old Dec 14, 2012 | 03:16 AM
Karanx7's Avatar
Unregistered Member
So I understand to use the Auto engine harness, but what about the dash harnesses? There are three inputs into the stock ECU: the Engine harness, and two dash harnesses. The manual harnesses are different than the auto ones.
If I use all 3 auto harnesses, that would make my life much easier. Will start looking for an EMS soon.
Old Dec 14, 2012 | 07:51 AM
fsttyms1's Avatar
Im not sure myself on if the dash harnesses matter but i would think the main harness would be the 3 plug Engine harness as the main reason it wont work on the manual motor is the crank position sensor (the wiring for that and the 2 cam sensors is different).
I should know in a few months when i get and install mine .........(that is if i can get my new, new engine put together cough 3.7 cough)
Old Dec 14, 2012 | 09:23 AM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
Nice I wish I lived closer so I could pay you to do some work on my car.
Old Dec 14, 2012 | 07:05 PM
assclown's Avatar
2000 acura tl FPR
The EMS has four plugs on it. A, B, C, D. A is your dash harness and B, C, and D are your engine harness plugs respectively.
However, One question I had when I was running the EMS was the plug on the driver's side of the OEM ECU. I had to have that plugged in to the OEM ECU and the rest of the plugs into the EMS or the car wouldn't start. I'm assuming because of the immobilizer?
TypeS860
Jan 10, 2026 11:11 AM
mlody
Dec 4, 2019 02:11 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
joflewbyu2
Oct 8, 2015 11:16 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
