2002-TL Spark Plugs
Old Feb 26, 2006 | 02:33 AM
jayman's Avatar
6th Gear
2002-TL Spark Plugs
Any suggestions on the best plugs or equivalent to the recommended NGK plugs below? They're $12-16 each!
Spark Plug PZFR6E-11 NGK
Thanks!
jay
Old Feb 26, 2006 | 08:14 AM
sbuswell's Avatar
I need 2 more gears
I got my NGK idirum IX plugs off eBay for 6 bucks a piece, check there.
Old Mar 6, 2006 | 06:06 PM
samkws's Avatar
Comptech Freak
the OEM plug is a double platinum so it's pretty expensive
you can try the single platinmum which is 5 bucks cheaper and same good performance, but u would want to change it sooner for best results
Old Mar 6, 2006 | 07:11 PM
sbuswell's Avatar
I need 2 more gears
get iridium's they create a stronger spark from what I've read and the NGK's are cheaper than the platinums.
Old Mar 6, 2006 | 07:46 PM
fsttyms1's Avatar
Or just spend the money on the oem plugs because they are rated for 100k miles and be done with it for another 100k
Old Mar 7, 2006 | 12:42 AM
jayman's Avatar
6th Gear
Thanks all for your suggestions. Decided to get the OEM.
BTW, do you also change the wires? Some say they're a lifetime product. If so, what wire is the best?
Thanks again,
jay
Old Mar 7, 2006 | 08:05 AM
NSXNEXT's Avatar
We don't have plug wires. We have a distributorless ignition. If you look under the hood you'll notice the 3 coil packs (black square things below the intake manifold. Those are what replaces the traditional distributor/plug wires. There are 3 more on the back side of the engine. You definitely don't need to replace them unless they go bad.
Old Mar 8, 2006 | 12:20 AM
jayman's Avatar
6th Gear
Right, thanks NSXNEXT for your suggestions!
jay
Old Mar 10, 2006 | 01:20 PM
samkws's Avatar
Comptech Freak
my plugs already pretty much done after 55k miles, with battery acid leaking and not so repsonsive
after i put new plugs i feel like i have a new car
Old Mar 10, 2006 | 03:02 PM
poohlikeshunny's Avatar
Money is funny.
I'm due for plug changes now, a lil over 100k, so what i understand is that i don't need to worry about the coils? if I just change out the plugs I'm good? I'm gonna DI-myself, so should I waste money on coils?
Old Mar 10, 2006 | 04:56 PM
acutee's Avatar
You don't need the coils unless they are bad.
Old Mar 15, 2006 | 09:23 AM
Timslunch2's Avatar
Are the rear 3 plugs hard to get at?
Old Mar 15, 2006 | 09:37 AM
optomos's Avatar
I=X - optomos
A little bit because its tight back there, but not to bad.
Old Mar 15, 2006 | 11:53 AM
supremox's Avatar
In changing the spark plugs, is there a need to change the gaps or you just plug it in?
Old Mar 15, 2006 | 12:12 PM
parshooter's Avatar
Back in the slow lane.
ALWAYS check the gap. One plug may fit many cars with different gaps.
Old Mar 16, 2006 | 12:57 AM
jayman's Avatar
6th Gear
Just changed the plugs. A couple of things:
1) The three rear plugs are kind of hard to get at especially if you have large hands. You'll need to remove/unscrew 2 brackets to gain easier access to the plugs.
2) Check the spark plug gaps. Should be 0.04 in or so. The PZFR6E-11 NGK were set at 0.04 in, but should check jsut to make sure.
j
Mike734
Dec 10, 2021 01:25 PM
acuratl26
Apr 23, 2020 07:30 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
