WRX vs TL-S
I raced one at the track last SAT....it had temp plates so i don't think he knew how to drive it yet.....long story short...i beat him!! only becuase i don't think he got a good start.....by the end of the 1/4 he was at my rear bumper......watch out there fast!! Same with Eclipses...turbo of course (91-98) I know... I had a 92 Talon TSI(turboAWD) zero dollar mods and your low 14's. i put an after market turbo on mine not much bigger than stock....and surprise, i pulled a 13.50..... spent $450 for a whole second gain...again watch out!!!!!
I know they are supposed to be dogs up at higher speeds
this doesn't add up since the turbo spools so late in one of those things. From dead stop you should have no chance. They run low 14's stock. Even an auto should take you, but at least it would be a race.
Originally posted by ferizzo
Depends on the driver. stock WRXs only have an advantage off a dead stop. There advantage is in the launch. on the highway you should be all set.
Am I wrong?
Originally posted by Davidas
Talking about good launch, the Audi TT Manual has a really good launch. I saw several TT (don'T know if 180HP or 220HP) with manual tranny launch very quick.
Am I wrong?
Am I wrong?
but i beat a TT starting at 40mph and pulled away with my 3rd in my TL-P
btw that was a 225hp version with twin exhaust
the WRX are very fast, and extremely fast if they do some mod....
My friend with an auto WRX is pissed, because I always spank him, from a stop or rolling ... doesn't matter. He's thinking of trading it in for a stick, but then it really matters on how good he can launch. With him, even if he had a stick, I'm confident I can still take him.
Originally posted by 2k2SilverTL-S
.....there's nothing like all wheel drive clutch drops at 5000 RPM'S!!!
I own them both
My wife drives an 02 TL type S with Nav. I drive an 02 WRX. We bought them both new in February and March respectively. My wifes is stock and mine used to be stock. You can see pictures of them at:
http://members12.clubphoto.com/ben58...r-324b-1.phtml
Let me know if the link doesn't work.
Stock in the Type S the best time I could pull was a 15.2
Stock in the WRX the best time I could pull was a 13.7
I have tricked the snaught out of my WRX.
Last time at the track I ran a 12.4. My 0-60 ft time was 1.61
Here is my parts list on my WRX:
Looks:
-Morette twin HID projectors, color matched
-STI foglight covers, color matched
-OEM front and rear chin lips, color matched
-Color matched grill
-Twisted i emblem on grill
-Debagged in rear
-Blue outlined WRX emblem in rear swapped for STI Red outlined version, and added MRT Enhanced emblem
-35% window tint
-H&R springs, camber bolts, custom alignment
-18 x 8 5Ziggen Frighters 48+
-Kumho tires 225 x 40 x 18
Performance: (note MRT is Middleton Rally Team from Aussie)
-GFB blow off valve vented 50/50
-Samco oversized turbo inlet pipe
-Samco high flow intercooler hoses
-MRT rampod intake
-MRT catless 3" turbo back mandrel bent exhaust, twin tip
-MRT catless uppipe with flex joint
-MRT header
-MRT intercooler sprayer kit and controller
-IHI VF34 ball bearing turbo with clipped impeller
-Supra fuel pump
-STi fuel injectors
-Blitz Electonic Sequential Boost Controller -ID, set to 16.5 psi.
-Custom made intecooler air splitter (inside the hood scoop)
-I'm sure that I am forgetting a few other things...
Looks:
-Debagged in rear
-35% window tint
-MRT rampod intake
-MRT header
-Supra fuel pump
-STi fuel injectors
Re: I own them both
Originally posted by 909
Stock in the Type S the best time I could pull was a 14.2
Yes that was stock, at sea level and about 55 degrees. About 1/4 tank of gas in each car. I don't know what to tell you, but that is what it ran. I do not have a reason to lie. Maybe my wife just got a really strong S from the factory.
SimTypeS, I would like to go but that is my anniversary weekend with my wife. Probably not a good idea if I want order my new lightened crank pully and flywheel.
Make sure you take some pics.
Originally posted by 1SICKLEX
WRX is a killer, it's whole purpose is to beat the EVO and be an all out sports car. WRX> TL anything in speed.
AKRY, You are right on the money about the STi. But you are a little off with your speed. A stock WRX starts to run out of steam at 131. It will do 131 in 4th at redline, but when you put it into fifth, there really isn't much more you will get out of it.
Throw some mods on it though and 4th becomes a very short gear while 5th will peg it against the rev limiter (if you have one)
MetalGearTypeS
08-29-2016 08:28 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
