wiring...
Old Jun 4, 2007 | 08:47 PM
sistom's Avatar
pwnage
Question wiring...
How can I wire something so that it turns on and off with the running lights and/or head lights? Please help.... Thanks!
Old Jun 4, 2007 | 09:46 PM
01tl4tl's Avatar
Use a 12Volt test light and find the wire for the hot power on those lights.
Clip a connecter to it - insert new wire and clamp shut- cover with tape.
Old Jun 4, 2007 | 09:49 PM
sistom's Avatar
pwnage
Am I an idiot because I dont know what that means? I mean there are like 23984723984729834 wires in that section where the fuses are... Just do it by trial and error?
Old Jun 4, 2007 | 10:23 PM
sistom's Avatar
pwnage
Or does anyone have a wiring diagram I can look at to find out where I need to go with these wires?
Old Jun 4, 2007 | 10:41 PM
EnvyAce's Avatar
Same question I asked heres the forum with pic
https://acurazine.com/forums/showthr...ing+headlights
Old Jun 4, 2007 | 10:44 PM
Bob_F's Avatar
Just as a general caution, be very careful when you're working on the wiring. If your're not careful you can fry some expensive electronics and you can actually disable your car.
One forum member had this happen recently while wiring up door handle LEDs.
Bob
Old Jun 4, 2007 | 11:08 PM
ThreePointTwoTeeEl's Avatar
3.2TL
Fttsmy (something like that) has a pic of the back of the drivers side fuse panel with a red circle, the circle is what you need to connect the positive to for the lights to turn on when you flip the side marker switch. I use that for my Footwell LEDs
Old Jun 5, 2007 | 04:34 AM
sistom's Avatar
pwnage
Well actually my car did start doing wierd things after I installed the wiring... My aftermarket alarm would lock/unlock the doors and some other small stuff but t seemed to work itself all out and now everthing is fine...
Old Jun 5, 2007 | 08:54 AM
sistom's Avatar
pwnage
wouldn't*
atsx1313
Aug 7, 2015 09:42 AM
grammo
May 25, 2012 10:16 PM
Bham03TLs
Feb 9, 2012 07:31 PM
riplee
Apr 6, 2011 08:29 AM
