Wires....
Old Apr 11, 2008 | 12:17 PM
Cisko TLS's Avatar
B A N N E D
Wires....
hi, id like to set up led lights at the footing area of my car, how do i tap inside the fuse box so that each time i open the door the lights come on, and then turn off when i close the door.
thanks
Old Apr 11, 2008 | 12:36 PM
EL19's Avatar
just tap into the courtesy lights on the door...or find a fuse that is for the dome lights or door lights
Old Apr 11, 2008 | 12:41 PM
Cisko TLS's Avatar
B A N N E D
thanks mr L
Old Apr 11, 2008 | 01:10 PM
Cisko TLS's Avatar
B A N N E D
L.... question like which wires go with which one and such, and use what gauge tap?
Old Apr 11, 2008 | 01:19 PM
EL19's Avatar
i would have to see a pciture cause i dont have my car and cant look at it...but usually the dark color is the negative wire...but not always the case...i would use a volt meter to test the wires or u could just ground the wire for the footwell lights and then tap the lights onto each wire to test. i would go with 18 gauge tap. But like I said early I would have to see the wires. You just take a pair or wire splicers and put the wire in the gauge measurer. That should tell you. Hit me if you have anymore questions
Old Apr 11, 2008 | 01:27 PM
Cisko TLS's Avatar
B A N N E D
TO BE HONEST IS NOT EVEN FOR ME IS FOR A FRIEND OF MINE... he got a tls 03 like me but he's dumb as shit lol
Old Apr 11, 2008 | 01:31 PM
EL19's Avatar
^^^^lmfao
jauman
Oct 17, 2017 09:20 PM
Simplydoesit
Feb 22, 2013 05:11 PM
swoosh
18
Jun 1, 2012 12:33 PM
saltyone
97
Mar 7, 2010 07:58 PM
poppintec
Oct 2, 2009 03:12 PM
