Windshield Wiper Problem
Old Dec 10, 2004 | 06:58 PM
soccerbenk's Avatar
I have a problem that my windshield wipers go to far and the blades hit the drivers side of the windshield and sometimes bump over it and get stuck with one blade sticking of the drivers side of my car. It seems to happen more when i am traveling at higher speeds or accelerating. Its almost as if the windshield wiper motors are two powerful and they are pushing the blades of the side of the window. any one have any thoughts on this problem?
Old Dec 10, 2004 | 07:43 PM
Bluenote's Avatar
Ex-Acura Service Manager
This is pretty common actually. I saw it alot, and on many Honda & Acura models.
If there is a little bit of room between the wipers & cowl when the wipers are at rest, you should be able to remove the wiper nut (14 mm if I recall) and move the wiper down by 1 spline, then tighten them back up.
Old Dec 10, 2004 | 08:53 PM
fsttyms1's Avatar
agreed. it may take a time or 2 but its easy to adjust
Old Dec 10, 2004 | 11:13 PM
soccerbenk's Avatar
ahh yea except i already tryed that i have it set as low as they will possibly go without hitting the hood each time they retract
Old Dec 11, 2004 | 02:06 AM
Street Spirit's Avatar
Hmmm..if you've tried adjusting the wiper arm itself (which should correct the problem) - are you sure you have the right size blades? If so, try getting some wiper 'wings' (right word?) to weigh them down a bit --- that will help keep them tight to the windshield at high speeds (reduces wind lift, etc). Or get wiper springs. Don't think the springs is the answer though.
Old Dec 11, 2004 | 07:35 PM
patrick's Avatar
Yeah I got this problem too, and it's only recently in the past couple of months. I'm getting my dealer to fix this problem when I take my TL in for my next maintenance interval. Which reminds me, I need to give them a call to book me in next week.
Old Dec 13, 2004 | 09:03 PM
My '99 did this for a few months off and on. Eventually, it did it every time, standing still or moving. My mechanic replaced the entire motor assembly, including the gearing mechanism (because, of course, Acura doesn't sell the gearing w/o the motor!). In short, I would have it checked out, because mine did nothing but get worse and ended up scraping up the top of my driver's side A pillar.
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
