Windshield Problem
Old Oct 17, 2003 | 10:13 PM
AznScratchRida's Avatar
Windshield Problem
There are stain marks/ a film of something on my rainshield that I can't get off. I tried using every possible material that can be bought but itz still there. Anyone have the same problem?
Back in Feb of this year, I brought my car to Markham Acura in Toronto and told them bout the problem, they said they would replace my windshield if they can't get the stuff off (dunno if I heard right)
But when I went to North Toronto Acura this tues they said that they will try the best to clean it up. So can anyone confirm that if this stuff can't be taken off, the windshield is still under warranty to be exchanged for a new one?
Old Oct 17, 2003 | 11:34 PM
sc354's Avatar
depending on the year of your TL, there is a recall for this problem on certain Acura's. It's a problem with the washer tubing deterioating and as a result smearing all over the windshield, and when you try to clean the windshield with anti-freeze, you're essentially making the problem worse.
you can print this PDF file from @curaW0rld
http://www.*cura*orld.com/tsb/2001/B01-004.pdf
replace the first * with "a" and the second * with "w"
anyhow, use this as a reference if you don't get satisfaction
take care.
Old Oct 20, 2003 | 06:21 PM
Thanks a 1000 times sc354!
Had the same problem without knowing what is was.
Pierre
Old Oct 21, 2003 | 09:29 AM
markhorowitz's Avatar
I have horrible streaks along my windshiels that won't come off. What can I try? I have the feeling that nothing will get them off. The service order mentions nothing about allowing for a new windshield.
Old Oct 21, 2003 | 09:35 AM
SK2003TypeS's Avatar
I use Einman Fabrik Window Cleaner for my windshield and windows. Safe for tint too. Stoner's Invisible glass is another great window cleaner. Windshield is one of the most neglected part of the car.
Old Oct 21, 2003 | 09:50 AM
jlongo_08807's Avatar
i got the same damn problem.
like streaks...
right?..
nothgin takes it off..
i tried compounding the glass also.
Old Oct 21, 2003 | 10:37 AM
Tom Blasing's Avatar
is the Mighty Favog
To get other tuff stuff off my windshield I've also used clay bar. It did a pretty good job but you still have to use some liquid window cleaner afterwards.
Old Oct 21, 2003 | 11:32 AM
Plexus.
If you can't find it, you might want to try 00000 steel wool and Windex.
Spray the window and lightly rub with steel wool in one direction only. Try a small corner area first to see if you get any scratches.
Old Oct 21, 2003 | 02:40 PM
Severin's Avatar
Try a straight edge razor blade; if that doesn't work nothing will. Some solvent like gasoline may help.
SidhuSaaB
May 30, 2020 12:40 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
