Window washer fluid low light
Old Jul 4, 2008 | 03:03 PM
TL-Super's Avatar
Light comes on..figure low on fluid. Put in a gallon..light stays on. WTF
Also my side airbag light is coming on regularly WTF
Old Jul 4, 2008 | 05:17 PM
`ill*tl's Avatar
Not sure about your washer fluid light not going off after you put more in.. I'm sure its nothing more than a simple sensor inside your fluid tank thats not registering that you have more fluid in there. As for your side airbag light, if you have someone or something leaning up against it.. it will go off and stay on until that someone or something has leaned off of it.
Old Jul 4, 2008 | 05:57 PM
cleex024's Avatar
yeah i would say its just the sensor for your fluid. take it back to the dealer and ask them whats wrong
Old Jul 4, 2008 | 06:50 PM
01tl4tl's Avatar
ASK the service manager AND parts desk if there is a common thing that goes out on that year
Its not worth 150 bucks to have them tell you it needs a new res sensor!
Do a little trouble shooting- do the sprayers work?
Book Spec on fluid capacity: USA cars, 2.6 usa qts
CANADA CARS 4.8 usa qts!!!!!
Have a read of the owner book for your car about side airbag light and why
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
If its the main SRS light- thats a special warranty issue
Old Jul 6, 2008 | 01:39 AM
totaledTL's Avatar
SRS light on could simply mean that fuse was pulled, or circuit opened w/out battery being disconnected.....
Old Jul 6, 2008 | 02:20 AM
01tl4tl's Avatar
we need to know WHEN the side airbag light comes on- if its when a buddy is in the car leaned against window, or has the seat layed way back - that will do it!
or you carry stuff in the passenger seat- that will trip the weight sensor
Have a read of the owner manual on how the system works- its designed to save passenger from injury if not seated correctly or too light- like a child
Old Jul 6, 2008 | 03:30 PM
bkzjimmy's Avatar
NiGhT rIdEr
does the 2000 tlp have the washer fluid light? ive never seen it.
Old Jul 6, 2008 | 03:40 PM
aznboi2424's Avatar
only canadian versions do.
Old Jul 6, 2008 | 03:56 PM
01tl4tl's Avatar
my usa 01 has it- check your owner book for details- thats where I found the specs on capacity- canuks hold over a gallon!!!
mada51589
Jan 9, 2025 04:40 PM
nanos
Nov 12, 2015 08:41 PM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
ahsm
Sep 9, 2015 08:35 AM
HeloDown
Sep 8, 2015 06:51 PM
