window not going up! help!
Old Oct 23, 2011 | 06:08 PM
02TL4ATL's Avatar
hey guys so i rolled down my window today and now it decided to no go back up. it wont roll down either. is there a way to manually roll it back up somehow? i know its not the motor because it was working fine earlier. i suspect that it is the wiring because some of the wirings looked cut up and spliced. probably from previous owner. i need help asap, its almost dark here
Old Oct 23, 2011 | 07:37 PM
Edward'TLS's Avatar
6G TLX-S
Is it just the driver's window, or all 4 windows ?
When you look at the group of 4 window buttons on the driver door's armrest, do you see the little green LED light up on each buttons ?
Old Oct 23, 2011 | 08:17 PM
02TL4ATL's Avatar
it was just the driver window. led still showed up. i did some searching and found an old thread saying to use speaker wire and run it from the battery to the window motor. that did the job. my driver window works fine now. goes up and down no problem. weird. well at least its fixed now
Old Oct 23, 2011 | 10:29 PM
sammy95's Avatar
I would fuse it at the battery. Wouldn't want any possible fires.
Old Oct 24, 2011 | 12:30 AM
Veritas23's Avatar
B A N N E D
yeah i would say check fuses
Old Oct 26, 2011 | 06:38 AM
d4atls's Avatar
Uhhh I would MOST DEFINITELY fuse it at the battery.... coming through the firewall / doorjamb is ASKING FOR A FIRE IF IT'S NOT DONE!!! Cabin fire = Very bad day : /
le^2
Mar 17, 2026 05:06 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
AcuraKidd
Sep 25, 2015 11:18 PM
