Will I rub a dub dub
Old Mar 18, 2003 | 12:15 AM
bronx02tl's Avatar
I am about to install OZ Superleggera 18X8 with a 45 mm offset, wrapped in 215X45X18 bridgestone potenzas dropping on H&R Sports with stock shocks. Can anyone warn me if I am going to experience the rubbage?
Old Mar 18, 2003 | 12:22 AM
hzm82's Avatar
ask on 'Tires and wheel' forum. there is a thread already that shows some config and if it causes rubbing
Old Mar 18, 2003 | 01:10 AM
bigman's Avatar
'Big Daddy Diggler'
Yes you will rub
Old Mar 18, 2003 | 02:20 AM
NSXDreamer's Avatar
I don't mean to be rude or something, but 18 is not considered dub!!
LOL.>>>... Hope rolling the fenders or getting 215/40 would prevent rubbing for you... to me, rubbing is the end of the world, my driving habbit cost my tires wear out every 3-4 months, go figure...
Old Mar 18, 2003 | 11:23 AM
bronx02tl's Avatar
I wasn't eluding that 18's were dubs...however I wish I could throw a nice set of dubs on my whip.
Old Mar 18, 2003 | 08:41 PM
bronx02tl's Avatar
Originally posted by bigman
Yes you will rub
what if i roll the fenders?
Old Mar 18, 2003 | 09:24 PM
GOT PSI?'s Avatar
It's Go-Time.
Just cut off the plastic tabs in the fenders.
Old Mar 19, 2003 | 11:42 AM
bronx02tl's Avatar
The plastic tabs are only found in the back...correct? Do you think I will experience any rubbing in the front?
What can I cut the plastic tabs with?
tks for your help
Old Mar 19, 2003 | 12:52 PM
accordv6's Avatar
tks for your help
For some reason rubbing in the rear is usually the only problem, unless you have some crazy offset or wheel width. I rub in the rear on rare occasions, but never in the front, even when turning a full circle at a decent speed.
Old Mar 19, 2003 | 07:34 PM
lhommec13's Avatar
I've been doing extensive research on this topic, and I've compiled a list of different rim sizes and offsets, and specifically whether they will rub with lowering springs installed.
I've noticed that many 18x8 wheels with 43mm offset will not rub, even with the car lowered.
So if your car isn't lowered, then I'd say it definitely won't rub according to my observations.
Good luck!
Old Mar 22, 2003 | 10:53 AM
bronx02tl's Avatar
what can I use to cut the plastic tabs? conventional scissors or do i need a dremel tool
Old Mar 22, 2003 | 12:06 PM
SilverUA5's Avatar
If you get 18x7 with +45, you can get a wider tire like 225 with 40 series and you won't even have to worry about rubbing.
Old Mar 22, 2003 | 03:59 PM
bronx02tl's Avatar
Good luck!
Thats just it...i want to lower it with H&R sports. Want to make sure it wont rub first.
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
Tribalheads
Sep 29, 2015 03:24 PM
