Will AEM V2 Intake fit 2000 TL?
Wilson
Looking to get the best Cold Intake for my 2000 TL. Any suggestions on whats the best? Also heard AEM V2 is good, will it fit a 2000?
AEM V2 will fit 99-01 TL because it uses the same application as the 98-02 Accord V6 (which has more of an aftermarket following). Only downside to a AEM V2 is that you can't fit a bypass....so a bigger chance of hydrolocking. Also the V2 is more expensive then all other intake for the TL. AEM V.1 can be fitted with a bypass valve and is cheaper.
Originally Posted by SONNYS99TL
well that would make the engine freeze, right?
Thx for the info on that V2. since I already ordered I may as well use it I guess I could return it and get a regular AEM cai and the bypass valve but I have no intention of driving it through any large amounts of water, but we'll see.
Even VSA? then NOPE it wont fit plug & play (That's why I was asking) The V2 was made for the TL-p only and it didn't took into consideration the extra space of the VSA Throttle Body. You will have to cut the V2 to fit.
I don't think its gonna die u know they solved the problem. My 6th gen v6 accord had 280k when I sold it & didn't slip once & we got it new. So I guess its in maintaining fluid. & I also bought a cooler when I bought that new trans because I read that heat was a main problem.
nanos
11-12-2015 08:41 PM
09-17-2015 09:01 PM
Abe_Froman
09-16-2015 01:27 PM
