where's the DIY for changing brakes/rotors?
planning on changing my front brakes and rotors this weekend, but i've searched and can't find the guide......??
i found the site for it alone w/ a bunch of other DIY
http://www..com/forums/forumdisplay.php?f=66
(a c u r a w o r l d) - put that inbetween www. and .com ... i don't know if they allowed me to have an off site link, so safe than sorry..
I'm Cool
heres a vid link from clubrsx forum, it should be similar hope that helps
http://forums.clubrsx.com/showthread.php?t=193049
i checked out the vid.
do we need to do everything that he did? like that part when he "bled" the brakes? or can we just simply replace and put that back in?
can someone tell me the torque specs for all the bolts? ... since he said it was important to do it right.
by any chance, can someone list the tools needed? since this will certainly makes things easier than running back and fourth to the auto store..
No, you dont have to bleed anything, because you are not removing the caliper.
i cant post the website here that has pretty good diy, but go to google and type this:
acura tl rotor pads diy
u will get a bunch of diys. Impact Screwdriver, C-clamp, and a lot of patience, is all you need. good luck
@ slide or die @
Thread started by me a while ago when i had the same questions...has all you need:
https://acurazine.com/forums/ramblings-12/christina-aguilera-show-e-108905/
basically:
1) remove rims
2) use impact screw driver to loosen the two bolts (see thread)
3)rotors should slide right out OR, hammer them out.
HAMMER HARD, the rotors wont even get scratched so dont be scared to hit em hard
and backwards to put back on
no c-clamp or jackstands needed...no patience needed either...hit the impact screw driver hard and then wack the rotor
basically:
1) remove rims
cycdaniel
12-17-2019 10:58 AM
pistacio
09-26-2015 09:45 AM
