where did i go wrong????CI
I think the part that sticks up should be turned so that is facing the ground.TL-S or TL-P? everything that I've brought comptech I think I've had a problem with the directions.great product but the directions suck.
It's upside down.....lol.... sorry but it's kinda funny
The plastic thing pointing up is a resivour for little ammounts of water to fall into.... the stock setup has the same...
Props to getting it in upside down, it must have been a beetch to install...
Flip it and you'll be fine... nothing should be pointing up...
you can pick up a tube at autozone forrealcheap.. just make sure it is engine tubing, otherwise the tube will collapse on itself when the heat from the engine rises..
Originally Posted by TLEXTREME
what did each of the two hoses connect to?
see thats all i needed was to be sure autozone would have it----now i should get it long enough to reach from the metal bar to the connection underneath???
It should be an easy fix.. Enjoy the HP
thankx for all the help my neighbors goingto autozone now well see if it works first mod and lots to go ....comming soon...aem power pulley,,ur undrive ,,,,,taillights....and when i win the lottery.......headers..and exhaust.
acuratl26
Apr 23, 2020 07:30 PM
Hines57
Sep 24, 2015 01:58 PM
