Wheel spin
Wheel spin
Does anyone know if you upgrade your suspension and get better tires that our stock ones on the 03 TLS will the limit or completely reduce wheelspin during takeoff??
It all depends on the adhesion ability of the tire to hold the road. ie- the softer the tire the better the grip. This is assuming the road surface is completly smooth and level with no debris at all. That and a down side is that the tread-wear rating won't be nearly as high.
tires and suspension will take care of alot of it
Originally Posted by r10apple
It helps, but with a higher power, front wheel drive car, anything short of track tires are gonna spin, esecially with the VSA off...
I got 99 Problems
Originally Posted by goldendragon576
don't stomp on the gas so hard and you'll elimate that problem without having to spend money ![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
JByron
01-08-2016 09:49 PM
Skirmich
09-15-2015 06:41 PM
