whats the difference!?
Old Aug 30, 2008 | 08:00 AM
Shocker0316's Avatar
Talking whats the difference!?
whats the difference between tl-p and tl-q? sorry for the stupid question!! Remember there isn't a thing such as stupid questions only stupid people!!
Old Aug 30, 2008 | 08:14 AM
MurdaZ's Avatar
p=poon
q=queer
i have an s, that means "supercool"
Old Aug 30, 2008 | 08:37 AM
6MTUA5's Avatar
No He Can't
Old Aug 30, 2008 | 09:05 AM
DC3328's Avatar
Your Garage
umm.. tl.......q???
Old Aug 30, 2008 | 09:11 AM
jjashaa's Avatar
Avant Garde Wheels
its TL-P and TL-S
tl-s is type s.. ooooooooooooooo
search it up. google everything.
Old Aug 30, 2008 | 09:27 AM
jjashaa's Avatar
Avant Garde Wheels
TL-P
Horsepower, SAE Net: 225 hp @ 5600 rpm
Torque, SAE Net: 216 lb-ft @ 4700 rpm
Redline: 6300 rpm
Compression Ratio: 9.8:1
Engine Block: Aluminum alloy
Stabilizer Bars: Front: 1.07 in./ 0.18 in.
(27.4 mm) diameter x (4.5 mm) wall thickness. Rear: 0.71 in
18.0 mm diameter, solid
Steering Type: Speed-sensitive, variable power-assisted, rack-and-pinion
Steering Ratio: 16.1:1
Steering Wheel Turns (lock to lock) : 3.11
Turning Circle (curb to curb) : 36.8 ft (11.2 m)
Anti-lock Braking System: 3-channel system with 4 wheel speed sensors and electric/hydraulic control
Vehicle Stability Assist (VSA) system: Not Available
Traction Control System: Detects wheel slip and coordinates modulated braking to return traction to slipping wheel
Curb Weight: 3494 lb (1585 kg)
w/ optional Acura Navigation System: 3510 lb (1592 kg)
__________________________________________________ ____
TL-S
Horsepower, SAE Net: 260 hp @ 6100 rpm
Torque, SAE Net: 232 lb-ft @ 3500-5500 rpm
Redline: 6900 rpm
Compression Ratio: 10.5:1
Engine Block: Aluminum alloy with spin-cast cylinder liners
(27.4 mm) diameter x (4.5 mm) wall thickness. Rear: 0.75in.
19.0 mm diameter, solid
Steering Type: Torque-sensing, variable power-assisted rack-and-pinion
Steering Ratio: 15.9:1
Steering Wheel Turns (lock to lock) : 2.93
Turning Circle (curb to curb) : 39.7 ft. (12.0 m)
Anti-lock Braking System: 4-channel system with 4 wheel speed sensors and electric/hydraulic control
Vehicle Stability Assist (VSA) system: Throttle control and brake control utilizing yaw, lateral g, speed and steering sensors for traction control and stability enhancement
Traction Control System: Incorporated into VSA
Curb Weight: 3538 lb (1605 kg)
w/ optional Acura Navigation System: 3554 lb (1612 kg)
There's your difference... other stuff are the same..
interior is a bit different too.
Old Aug 30, 2008 | 09:44 AM
OneCleanTL-S's Avatar
AZ Member.. :X
Cool
IM so proud...
Old Aug 30, 2008 | 11:30 AM
Trackruner228's Avatar
You got that Quote from south park....
Old Aug 30, 2008 | 06:38 PM
dreem1er's Avatar
deal with it
whats the diference...umm......a tl q comes with queso...
Old Aug 30, 2008 | 10:22 PM
Mista Juice's Avatar
im sure its been covered many times, but since this thread is active, what does the "P" stand for?.. before getting on this board, i and many of my friends simply called it the TL and the TL-S, no P..
Old Aug 30, 2008 | 10:48 PM
6MTUA5's Avatar
No He Can't
Premium
Old Sep 1, 2008 | 08:36 PM
Rajca's Avatar
wham bam thank you ma'am
tl-p is slower then tl-s
Old Sep 1, 2008 | 08:57 PM
6MTUA5's Avatar
No He Can't
You shut your mouth
Old Sep 1, 2008 | 09:08 PM
Rajca's Avatar
hey kris, u get your car running at full potential? i guess u got a tl-p6 (6 for 6 speed for those who dont know)
Old Sep 2, 2008 | 01:32 AM
03aspec's Avatar
i have the a-poop edition with them fancy blue things in the seats
Old Sep 2, 2008 | 05:42 PM
dreem1er's Avatar
deal with it
Old Sep 2, 2008 | 10:08 PM
Jake 6MT's Avatar
Clemson Tiger
Haha i love how below your name it says anus spec. What I would do for an aspec..
Recipe7
3G RLX (2013+)
45
Dec 7, 2015 06:43 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
joflewbyu2
Oct 8, 2015 11:16 AM
thegipper
Sep 28, 2015 01:01 PM
eastcoastguy
Sep 23, 2015 06:29 AM
