What tranny fluid to buy ?
I am looking for a tranny fluid for my 2000 TL ? a great product but inexpensive that is available at Walmart, Part Source, Canadian Tires, big name stores.
When is it recommended to change the tranny fluid ?
I believe you're supposed to change it every 50k miles. A friend of mine told me it was because after that your tranny starts seeling itself, and if you change it then you might have leaks. I would stick to oem fluid but maybe someone else could give you better advice on that.
Walmart..
.....inexpensive...
.....u can start saying buh bye to ur tranny...only use the one mentioned above..honda fluid for our trannies...spend the extra bux and get the correct fluid..
.....inexpensive...
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
Are you doing a 3 quart flush or a 3x3?
Dont use ANYTHING except for Handa / Acura ATF Z-1 fluid.
Its like 6-7 dollars at any honda/acura dealer.
$25 for 3 quarts of z-1 is alot cheaper then a new tranny!
cars with higher miles (more than 30k) should stick with the acura method and do a simple drain and refill-
the trans will only give up 3.2 qts of its 7.something capacity at a time- the rest is tucked inside other parts
Doing a full~ `flush per acura description` is 3x3 with a 4th fill
thats supposed to be `in an emergency when you put dex3 in the trans` and need to remove all traces of it
While I dont agree with acura on a technical oil basis, there is no denying that a full 3x3 will often lead to failure of a higher miles trans
Toooo much cleaner and slippery stuff in the new fluid
Stick with Honda ZR1 at import parts stores or honda dealer for best price
Never hurts to ask the parts dept for a price match to honda is they are close together
30 bucks will do what you need for now- then in 6 months do another 3
Stay far away from machine suction or power based units that flush fluid thru and out- its not the right fluid and not the right method
for example - I did a drain and fill (3Q out and 3Q in) 2 times at 65k miles and I have done this every 15 or 20k since (probably overkill but I don't mind). I now have 154000 miles on the original transmission and all is well. you should be fine at your mileage to do a simple drain and fill. if you do this 2 times then you will not get all of the old fluid out but most of it. I really think that will be just fine. As it has been said avoid the power flush that is offered at your local mechanic shop.
now if the tranny had well over 100k miles and everything was still fine, I would think it would be better to leave it alone.
B A N N E D
If it where me I would only drain 3 and fill 3!
then do it again in like 5k miles if u want just DONT do the 3x3 if u dont know the history of the tranny!
My dealer, Jerry Damson Acura in Huntsville, charged a little over $8 per quart. Their parts department is pretty good, they have offered me pretty much everything I've asked for at a discount, plus usually no waiting and no shipping charges/times, unless the part is out of stock and they have to order it (but they don't charge me any shipping either).
If they do youre getting ripped off..lol.
i'm doing a drain and fill this weekend. I go to UTI and i guess we get discounts at dealerships so i'm gettin 6.86 a qt. pretty sik. i've just gotten my car bak for a few weeks now w/ a re-built tranny. i'm guessing its pretty safe to do a drain and fill with my tranny that has 6k on it correct?
Honda sells the exact same stuff for less $ per qt
do NOT use seafoam or seafoam for trans in the TL trans!!!!!!!!!!!
Well - maybe if you want to say goodbye to it~
Remember all the talk about removing too much needed crud with a 3x3 fluid change??--imagine using seafoam to dislodge way more than that, -it will be clean but, IMO, would be headed for the shop soon
blak-
no need to start on a change so soon- 15k miles will do nicely for a straight 3 qt drain and refill
Or if you want to, because you have a fresh low miles trans- go ahead and start on a 3x3 when you hit 15 then every 15
Waste of money and oil to start at 5
Ok I see, I guess ill stick to the 3x1. My trans feels good I just like 2 maintain my car so I'm wondering I should do and it sounds to be safe the 3x1 is what ill go for and go from there. Thanks fellas.
tranny fluid
