What sort of bypass valve is this??
Former Sponsor
Hey guys, i washed my car today and later on when i was about to start it i noticed a clicking noise from the engine bay, sort of like the noise that a bad starter motor would make, the noise itself was very brief and low. I opened the hood and had my coz start the car for me, and right before you start the car, when the ignition key is at "ON" position, thats when this following part made the clickin noise for a second. When i started the car it wasnt there, tried it a few more times with the same result. It makes the sound when you turn the key to ON and when u start the car up its not there any more. The part itself says "bypass valve". I am just wondering what caused this
and whats the fix. The part is located right behind the engine itself, right next to the strut tower bar. ![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
![](http://i153.exs.cx/img153/8624/tl3ni.jpg)
Former Sponsor
OK this is the info that i got from the acuraparts247.com website. The part itself says " ACTR BYPASS VALVE" on it. THe part number, actually on the part itself is 17150-PFW-J01 (for an 03 TL). On the website it is listed as part number 17151-PFW-J02 as ACTR, BYPASS VALVE for $83.28 . I will call the tech at the dealership today and see what he says, if it needs to be replaced i will do so, and i suggest black you do the same. WIll keep you posted.
Former Sponsor
Thanks pure,
i just spoke to the tech at the local acura dealership. He said it is suppose to make that noise , and you probably never noticed it. What it does is it triggers the EGR valve, exactly what you said pure.
Former Sponsor
Originally Posted by Black3.2
so if it ticks then its a good thing right?
Liquid Ice
The way to test it is to have someone rev the car up in Park to 4000rpms or more.
You'll see the Actuator flip open. If it flips open at around 4000rpms, and then flips closed as you're coming down below 4000rpms, then its working.
If its not, you should get your dealer to replace the part. Its good for about 20hp or so in the midrange.
Note: Only Type S models have the IMRC. The Premium models don't have it.
Here's a great video showing the IMRC in action:
https://acurazine.com/forums/showthr...highlight=IMRC
The link to the video in the above URL isn't working anymore. Here's the older video which isn't as good, but it still shows you what the actuator looks like in action:
http://www.geocities.com/~gamesmgr/chod/acura/#Driving6
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
