What needs to be done?
My TL is now at 168,000km that is 105,000 miles. Just wondering what needs to be change and replaced
Already done timing belt, water pump and tranny fluid change
Bonki' Ehrite!
If the 105 service has already been done (timing belt, water pump, etc), I would just do a flush on all the fluids and make sure your mounts are all good and you should be good to go for quite a while.
beside the extreme torque being placed on the cv joints as big stuff moves?
and the vacuum assisted mounts cause a vac leak so the car runs funny?
Touring,, what are you doing riding around on bad mounts!! you know better~
valve adjustment is good plan- I should have said that- thanks totaled
Did they replace the idler pulley when they did the timing belt? If not, I would do that first. If that goes, it'll be time for a new engine.
Check the invoice from the timing belt service to see if they replaced it.
(http://www.youtube.com/watch?v=nDovD-k4Hvo)
side note
that's right VU-Spec
Im talking about the ac pulley- its at the very top- behind the alternator
You can place a screwdriver on its base and listen- or a proper mechanics stethascope $5 harbor freight tools, 10 at parts stores, make noise detection easy
easy way into the ac tensioner pulley is thru the right fender panel
